Mpi No Power To The Wheels
20 replies to this topic
#1 Drextek29
Drextek29
  • Validating
  • 11 posts
Posted 29 September 2016 - 10:07 PM
Hello,
I purchased a 1380 engine and transmission from the UK and had it shipped to the US. Its in the car, and I filled with break in oil and ran above idle to break-in the engine in. I was double checking the tappets clearance and noticed when in gear I couldn't turn the front tires to advance the cylinders when in gear. The tires could be moved but no change in the tappets. I started the car put it in gear the the tires slowly moved but I could easily stop them. The speedometer moves when in gear. Thought maybe it wasn't all the way in gear as I had added a quick shift from minispares. Installed the original shifter and have the same issue. Any ideas on what it could be?
#2 Spider
  • 15,144 posts
Posted 29 September 2016 - 10:15 PM
Clutch?
#3 nicklouse
  • 18,697 posts
Posted 29 September 2016 - 10:41 PM
Both wheels on the ground? Or one on the ground or non on the ground?
Bought from who?
#4 Drextek29
Drextek29
  • Validating
  • 11 posts
Posted 30 September 2016 - 04:50 AM
It was on ebay, my mini15 who had several engines sold. He hasn't responded to my emails about the engine. It appears to be well built. Changed the head with a minispeed stage 4. Front wheels off the ground. When I push in the clutch the tires stop spinning.
#5 nicklouse
  • 18,697 posts
Posted 30 September 2016 - 07:15 AM
cant find a seller with that ID.
with both wheels off the ground you will not turn the engine.
#6 nicklouse
  • 18,697 posts
Posted 30 September 2016 - 07:18 AM
but now I have changed the search on here I think I would be pulling the engine and rebuilding it.
http://www.theminifo...15#entry3411957
http://www.theminifo...15#entry3287024
and
someone who had issues
http://www.theminifo...-1275-40/page-1
#7 MacGyver
MacGyver
  • 1,027 posts
Posted 30 September 2016 - 07:20 AM
Sounds like the differential crownwheel doesn't touch the pinion...
Hope I'm wrong. 😐
#8 timmy850
timmy850
  • 3,388 posts
  • Local Club: MITG
Posted 30 September 2016 - 07:46 AM
This is the guy?
http://www.ebay.co.uk/usr/miniengz
#9 pete l
pete l
  • 1,379 posts
Posted 30 September 2016 - 08:48 AM
I had something similar on a metro once, it was the front hub splines that has gone, a new CV joint and hub and all was well.
#10 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,147 posts
  • Name: Sean
Posted 30 September 2016 - 09:38 AM
Hate to say it but you've probably been ripped off with the engine.
The seller is a known crook and sells utter junk engines.
I know of at least 4 people who have bought of him(and from his other eBay IDs).
To date i don't think he has had a single satisfied customer.
You need to start trying to get your money back asap.
#11 Drextek29
Drextek29
  • Validating
  • 11 posts
Posted 30 September 2016 - 01:57 PM
Thank you everyone for the quick feedback, just waking up in Seattle. It looks like he might have had a few names but email was [email protected] . I have 2 year old twins so don't get much time to work on the car. I purchased last Nobember and took 3 months for it to get here. The paint was horrible and sloppy so I removed and repainted and also added a dns timing cover to it. Everything on the car has been powder coated as well. Took me some time till I put the engine back in.
I'll keep you posted on what I find.
 IMG_3654.JPG?dl=0
IMG_3697.JPG?dl=0
#12 pete l
pete l
  • 1,379 posts
Posted 30 September 2016 - 02:57 PM
If the speedo is moving then it's not the clutch.
can you hear any metal on metal sounds as it's trying to turn the wheels ?
Are you driveshafts pushed right in to the gearbox / diff ?
Can you see a driveshaft turning but not turning the wheel ?
#13 Drextek29
Drextek29
  • Validating
  • 11 posts
Posted 30 September 2016 - 04:40 PM
Yes I can hear metal sounds and the drive shafts are all the way in. The drive shaft turns with the wheels.
#14 MacGyver
MacGyver
  • 1,027 posts
Posted 30 September 2016 - 07:40 PM
As your car is in the air, try this:
In gear ( engine off), when you turn one wheel, the other should go the other way.
But as you have speedo turning but not wheels turning when trying to move, I suspect nothing will happen...
#15 Drextek29
Drextek29
  • Validating
  • 11 posts
Posted 01 October 2016 - 05:47 AM
Your correct, nothing happened. Why is it that the other wheel should  go the other direction?
