Hi guys.
Lately I've been having an absolute mare with my twin 1/4" SU carbs. I've just finished a restoration (complete with metro 1275 transplant) so the car hasn't seen the road yet, but it's already blowing black smoke and I just can't get the engine to run right; lots of coughing and spluttering. The points are good, and the plug gaps are spot on, but every time I check the plugs they're completely black. (plugs and HT leads are brand new by the way).
The general consensus between me and my dad is that the car running way too rich, but the after tightening the nuts under the carbs that adjust the mixture (the technical term has escaped me) as far as they go, assuming this will make the mixture leaner, it seems to have made little to no difference... On top of this, if I adjust the timing to it's correct position, the engine nearly dies and seems much happier running with the distributor rotated slightly clockwise...
I'm scratching my head here, could this be a case of needing longer needles for the carbs? Can you even buy longer needles?
Any advice would be much appreciated!
Chris
