https://goo.gl/photo...jMaWmazPPsi4Pq9
I'm currently trying to swap a 1989 Austin metro 1275 automatic engine into my 1991 mini city 998 automatic. Front subframe is out the mini as well as both engines. Swapped engine mounts and bell housing over today but when lowering the engine onto the subframe to fasten engine mounts I found the brass part in the enclosed pic (link) was catching in the subfeZne preventing mounts on bell housing side to line up, anyone know what it is and how I can alter it? as the 998 engine just has a bolt screwed in the that hole but the metro had this brass part screwed in with a spring in the hole making it extend further.
No replies to this topic
Mini Technical Sections →
Problems, Questions and Technical →
Excessive Fuel Pressure - Regulator Or New Pump?Started by daddums , 20 Aug 2025 ![]() |
Econoseal Or Something Else?Started by o0OWILKSO0o , 13 Aug 2025 ![]() |
What Size Are These Main And Big End Bearings?Started by scottyboy805 , 19 Jul 2025 ![]() |
engine
Spi Bad Idle And 'tapping' Engine SoundStarted by Simmi Westo , 15 Jul 2025 ![]() |
![]() Help! Water In Oil Question....Started by TerryLee , 06 Jul 2025 ![]() |
