It could be a slightly warped disk then...?
I hope not. £50 ouchy!
Posted 19 September 2006 - 12:07 PM
Posted 19 September 2006 - 12:08 PM
Posted 19 September 2006 - 12:10 PM
Edited by mini93, 19 September 2006 - 12:11 PM.
Posted 19 September 2006 - 12:43 PM
Posted 02 April 2007 - 05:05 PM
Posted 02 April 2007 - 11:11 PM
Posted 03 April 2007 - 12:10 AM
Posted 03 April 2007 - 04:51 PM
Squeeking can be caused by not having the castle nut in the centre of the hub tight enough. sometimes, when rebuilding after bearing change etc, it is hard to get the leverage required to get it tight and then move it round another slot on the castle to get the split pin in. some people (me included) end up backing it off a liitle instead. Its still tight but not enough so after awhile the tapered ring that the castle nut presses on starts to move about in its housing. . . the movement is very small but will squeek none the less.
By the time i realised what it was the tapered face on the ring was practically mirror polished!
If you can't find any pad, disk etc interferance look here.
