Rear Bearing Castle Nut Pin Problem
#31
Posted 28 February 2017 - 06:20 AM
HOWEVER..... the second set as stated. Are genuine timken.etched on both bearing race and bearing and came out of sealed packets ..
but what i did notice....although etched the codes between the bearing and the races did NOT match which i thought was odd.
The codes on the non genuine races matched them of the timkens. ..
I think what im now going to do before i go ANY further is im going to order another "timken" and see how it looks when it arrives before fitting anything else.
Because timken on not it still had the same problem.
#32
Posted 28 February 2017 - 07:11 AM
Yes the one set i believe not to be timken...
Edited by neal, 28 February 2017 - 07:11 AM.
#33
Posted 28 February 2017 - 07:13 AM
If the codes etched don't match then they are not a matching pair, I wouldn't use them but it's up to you, as before good luck.
Edited by neal, 28 February 2017 - 07:14 AM.
#34
Posted 28 February 2017 - 12:26 PM
It sounds like someone in the supply chain is up to their usual tricks. Sad, but it happens a lot nowadays.
Your best bet is indeed to procure a genuine matched pair of Timkens. I hope it goes well.
#35
Posted 10 March 2017 - 05:42 PM
Please tell us WHERE YOU BOUGHT THEM
#36
Posted 11 March 2017 - 11:47 AM
#37
Posted 13 March 2017 - 01:03 PM
I have the same problem with my bearings. Minispares article GHK1805 Genuine Timken box, quality of the bearings looks verry good but there is a gap between the nut and pin.
#38
Posted 13 March 2017 - 03:07 PM
Edited by cian, 13 March 2017 - 03:09 PM.
#39
Posted 27 February 2018 - 02:53 PM
Do you still have these in stock ?
#40
Posted 27 February 2018 - 03:42 PM
