Can't Get Low Enough
#16
Posted 10 April 2017 - 08:44 PM
#17
Posted 11 April 2017 - 05:55 AM
bump stops,,,,,,,,,,, they are rock hard! .
Gotta agree. The standard Bumps stops are very awful things. I'd forgotten that!
Try the Competition Type Bump Stops. They do mount to the Arm, so not quite straight forward as you'll need to drill out the mounting bracket they come with, however, while with the standard bumps stop YOU KNOW when you've touched them, however, with the Competition Bump Stops you will have no idea if you are on them or not. It's almost like have a secondary spring rate.
#18
Posted 11 April 2017 - 05:58 AM
Is trimming them down a massive no no or just not the best option? Not talking making massive cuts just shaving a few mm off the bottoms.
#19
Posted 11 April 2017 - 06:38 AM
Trimming them will make them shorter, but if the shape is lost, the harder will only become harder!
Personally, I wouldn't quite say a no-no, but certainly not the way I'd go.
With the Competition Bump Stops, they are internally shaped and slightly less in height than the standard ones. Being shaped the way they are, they are progressive in rate, so unlike standard bumps stops, you can actually 'ride' on them to some degree.
#20
Posted 11 April 2017 - 01:39 PM
How much of a pig to replace?
#21
Posted 11 April 2017 - 06:31 PM
The standard bump stops are a pig to replace, as the nuts are inside the subframe tower. Not a fun job.
The Competition ones fit the the shocker bolt on the suspension arm, so are very easy to fit, you just need to drill out the hole from 5/16 to 3/8" clearance.
#22
Posted 12 April 2017 - 07:56 AM
I'll look into a set of competition ones
#23
Posted 12 April 2017 - 07:58 AM
Would it be possible to cut the old ones out then?
just unbolt them.
#24
Posted 12 April 2017 - 08:00 AM
Or this one.....https://www.minispar.../C-AJJ4007.aspx
I've just fitted hi-los and new cones so don't really want to take then out again
#25
Posted 12 April 2017 - 08:18 AM
These https://www.minispar.../C-AJJ4007.aspx
Gotta say, I cut the old stops off these days - lazy I know, but I can't see the point in disturbing everything else to undo something I'm only throwing in the bin.
#26
Posted 12 April 2017 - 09:02 AM
#27
Posted 14 April 2017 - 01:40 PM
The suspension definitely feels better but still can't get it low enough for my likings.
Looks like it will be different wheels / arch modifications.....
#28
Posted 14 April 2017 - 01:43 PM
Looking around there is loads of minis much lower than mine.
Mine is on the bumpstops and can still get 2-3 fingers between wheels and arch.....
Edited by matt050990, 14 April 2017 - 01:45 PM.
#29
Posted 14 April 2017 - 01:57 PM
That will give you a real figure rather than measuring against a wing that may have been correctly.
#30
Posted 14 April 2017 - 02:00 PM
