How To Fix Mini Cooper 02 Heater?
electrical
3 replies to this topic
#1 Zeppedy
Zeppedy
    Starting My Mini Up
  • 2 posts
Posted 22 March 2017 - 05:08 PM
Hi All
I have a Mini Cooper 02, and a few days back the heater stopped blowing hot air - the fan blows air fine, but it's not heated.  Just when the cold snap arrived too so great timing
I browsed online, and saw some suggestions to check fuses and coolant level.  Fuse was fine, but the coolant was empty.  I added in the coolant last night, but the problem remains today.
From what I've seen online, it could now be an airlock, or other's suggest I service the heater myself as it';s not a big job when you know how.  But I don;t!  Could anyone offer any suggestions on
a) How to determine if I have an airlock in the coolant flow and/or
b) Suggest anything I can try to get the heat working again (bar waiting on some seasonal weather)
Thanks in advance......
#2 gazza82
gazza82
  • 3,087 posts
  • Local Club: TMF+
Posted 22 March 2017 - 05:26 PM
Check that there aren't any bleed valves in the heater hoses high in the engine bay. Newer cars often have these. you can open them with a screwdriver and if coolant comes out, it isn't an airlock there.
If you have drained the coolant it is possible it is an airlock. Try starting the car and allowing it to warm up with the coolant cap off the car and see if you can see any bubbles pushing back out of the header tank.
This is actually a site for Classic Minis .. your problem is similar on most cars, but Mini2.com might be a better forum to ask on.
Edited by gazza82, 22 March 2017 - 05:27 PM.
#3 Zeppedy
Zeppedy
    Starting My Mini Up
  • 2 posts
Posted 23 March 2017 - 10:53 AM
Thanks gazza82, I'll check those out.  Apologies, didn't realize I was on a classics forum..
#4 gazza82
gazza82
  • 3,087 posts
  • Local Club: TMF+
Posted 23 March 2017 - 05:07 PM
Not from the questions when you signed up???
