Edited by Minigman, 24 March 2017 - 05:27 PM.
Disappointing 998 Performance
#16
Posted 24 March 2017 - 05:26 PM
#17
Posted 24 March 2017 - 05:34 PM
Have you done a compression check to see if all is well?? Low mileage or not, worth a quick check.
#18
Posted 24 March 2017 - 05:36 PM
I can't see getting the benefit of a 12G295 with stock exhaust ports no matter how high you lift the valves because they're the major restriction.
#19
Posted 24 March 2017 - 05:38 PM
#20
Posted 24 March 2017 - 05:45 PM
Would have thought a decent fast road 998 with 266 cam would be good for 60-65 bhp? The max torque also seems to be well up the rpm range, would have expected peak before 4000.
Have you measured the actual valve lift? 266 is low on lift at lobe. For instance if you use A+ rockers with 266 in a 1275 it won't breathe properly at high rpm.
If you're getting carb icing problems with the Weber a change to SUs makes sense. A HS4 on a decent alloy manifold with water heating connected should do the business.
#21
Posted 24 March 2017 - 06:19 PM
It was timed in accurately. The chap that did the work builds race engines so I've no reason to doubt him. It's been back in to him to be checked over. I'm just wondering if the Weber DCD is letting it down. Plumbed in the heated inlet, fitted electronic fuel pump and regulator set to 2.5. Taped up the front of the K&N to stop the icing issue. It goes ok but not as good as previously owned cars. Went small bore instead of the 1380 route this time as I remember my old 998 in the 80s with a stage one kit went like the clappers. I'm just not feeling it with this set up sadly. Might need a trip to Slarks for further investigation.
Minigman, agree! My 'Red Hot' with a Stage One, was great around the streets of London, back in the 90's.
Q. I have a std. 998 from '78 with 50k. It's been on a rolling road, just to get it tuned right & I was told it was a 'tired' engine & adding a Stage One, might have a knock-on affect to vunerable components. Asking for a second opinion, and by no way, undermining the credibility of the initial opinion, what do you think.? Save up a grand or two & get it re-built, or chance a Stage One..?
cheers
#22
Posted 24 March 2017 - 06:32 PM
Stage one it. Mine has 80K and I've been driving it hard for three years and it's taking it fine. These are pretty tough motors and you won't be making enough HP to do any significant damage unless it's really knackered already, assuming your oil pressure is reasonable and blow-by is low.
#23
Posted 25 March 2017 - 03:16 PM
If you do manage to break it, they are really cheap to replace compared to a 1275. Lots of practical things in its favour. Have fun! (If it isn't fun, you need a new hobby...)
#24
Posted 25 March 2017 - 04:26 PM
Edited by whistler, 25 March 2017 - 04:39 PM.
#25
Posted 25 March 2017 - 06:16 PM
Oil pressure's fine.
what the hell is blow-by.?
#26
Posted 25 March 2017 - 07:05 PM
Combustion Gases that are 'blowing-by' the rings.
#27
Posted 25 March 2017 - 08:37 PM
#28
Posted 25 March 2017 - 08:39 PM
Edited by Minigman, 25 March 2017 - 08:42 PM.
#29
Posted 25 March 2017 - 09:14 PM
Are you sure the CR is 9.8:1? Who measured it and who skimmed the head to get the right chamber volumes?
A 998 with that sort of spec should give c.60 bhp at around 6000 rpm.
I guess it could be a mis-match of components with the carb being the chief suspect.
Is the distributor curve right for the engine spec?
If you fit a pair of HS2 carbs it will be a 998 Cooper spec plus, so the bhp should be over 55. The induction system is suspect here. There were no carb icing issues with twin HS2's and the manifold was not heated.
#30
Posted 25 March 2017 - 10:44 PM
