Is the carb new or freshly rebuilt. I know from experience with 32/36 DGAV's that the wrong jets will cause all sorts of aggro. Also air leaks are another issue as well. Correct float height etc etc.
Disappointing 998 Performance
#31
Posted 25 March 2017 - 10:47 PM
#32
Posted 25 March 2017 - 10:50 PM
I'll also add to my other comments that of the machining of the block in the first instance isn't up to scratch, you'll also loose power form that, however, as per my first, and your dyno figures,,,,,,,
Edited by Moke Spider, 25 March 2017 - 10:51 PM.
#33
Posted 26 March 2017 - 04:02 PM
Testing on another dyno would probably be the best thing to do, or at least a road comparison with one of known similar HP and torque figures. I would try advancing the cam 4 degrees and see if that helps.
#34
Posted 01 August 2017 - 10:47 PM
Now getting 56bhp with 57 torque.
Throttle response is phenomenal compared with the Weber. It feels like a different car!
Edited by Minigman, 01 August 2017 - 10:47 PM.
#35
Posted 05 August 2017 - 11:39 AM
If you did a bit of mild gas flowing to the 295 head by removing the inlet and exhaust guide bosses and de-shrouding the valves a bit you would see a further improvement. Also, did you clean up inlet manifold for the SU's? That also helps a bit more.
You should get around 60 bhp if you do those extra and easy improvements.
#36
Posted 06 August 2017 - 10:07 PM
How's the 850 coming along Peter?
Edited by Minigman, 06 August 2017 - 10:11 PM.
