Head Gasket Leak
32 replies to this topic
#16 Spider
  • 15,063 posts
Posted 28 April 2017 - 08:42 PM
If your old head gasket fire rings failed between cylinders 2 & 3 causing loss of compression, an excess amount of heat would have been apparent in that localised area whereas the rest of the cylinder head face and block would be at a more consistent temperature.
Retarded Ignition Timing will do just this.
The Exhaust Valves for 2 and 3 and right there together and these alone make for a 'natual' hot spot in the head. Retarded Ignition timing only makes that much worse.
#17 minidave54
minidave54
  • Just Joined
  • 184 posts
  • Local Club: IMOG
Posted 28 April 2017 - 08:43 PM
Neal, I will remove the studs and check the head and block face tomorrow also looking for any sign of fretting of the threads.
To answer your other points, the head gasket came from a mini spares head set for an spi.
The water was leaking all along the joint face on the front of the engine between the head and block. There was no signs of any water leak from the rear of the engine .
#18 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,068 posts
  • Name: Neil
Posted 28 April 2017 - 08:48 PM
I had this with a minispares gasket kit for a 998. Copper gasket. It leaked water and oil. You need a Payen HG.
#19 minidave54
minidave54
  • Just Joined
  • 184 posts
  • Local Club: IMOG
Posted 28 April 2017 - 08:50 PM
RooBoonix, that's interesting reading as that is the very gasket set i had fitted.
I now have a new gasket, it's there upgraded Payen AF470, mini spares identify GUG705550GM. Maybe fitting this with new studs and nuts might also solve my problem. But i will also carry out the other checks as suggested by other members on here.
#20 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 28 April 2017 - 08:51 PM
When you remove the studs make sure there's no thread sticking out round the stud hole. Were the studs fully screwed into the block? You need to try and find something substantial to wrap some fine wet and dry round to see if there are any low points on the block.
#21 minidave54
minidave54
  • Just Joined
  • 184 posts
  • Local Club: IMOG
Posted 28 April 2017 - 08:54 PM
Moke Spider, the engine I have is an SPI, so as you are probably aware ignition timing and mixture are all controlled by sensors and the ECU.
#22 minidave54
minidave54
  • Just Joined
  • 184 posts
  • Local Club: IMOG
Posted 28 April 2017 - 08:56 PM
Thanks Sonikk, i now have a Payen AF470, so this might help.
#23 neal
neal
  • 318 posts
Posted 28 April 2017 - 08:59 PM
Is it leaking in the middle at the front, what I'm trying to work out if it is related to where it over heated between cyls 2 & 3 and possibly warped??
#24 neal
neal
  • 318 posts
Posted 28 April 2017 - 09:04 PM
Me thinks your just going have to whip the head off and take your time checking, checking & checking. Good Luck.
#25 minidave54
minidave54
  • Just Joined
  • 184 posts
  • Local Club: IMOG
Posted 28 April 2017 - 09:08 PM
Neal, I will remove the studs and check the head and block tomorrow also looking for any sign of fretting of the threads.
It was leaking at various points all along the front of the engine from cylinder numbers 1 to 4. It was as if there was a gap along the front between the head and the engine block. When I removed the head there was no signs of any water in any of the cylinders.
#26 neal
neal
  • 318 posts
Posted 28 April 2017 - 09:15 PM
Interesting, sounds like fretting on the threaded holes or threads exposed on the studs not allowing the head to compress the gasket down, but I'm sure you'll find out.
Let us know how you get on!
#27 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 28 April 2017 - 09:17 PM
You need to check the face of the block to make sure it's true.
#28 neal
neal
  • 318 posts
Posted 28 April 2017 - 09:23 PM
Fingers crossed eh Dave? Hope its just fretting or studs or maybe a dodgy head gasket
#29 minidave54
minidave54
  • Just Joined
  • 184 posts
  • Local Club: IMOG
Posted 30 April 2017 - 08:34 PM
Not had much chance recently to look at this further in any detail.
Did try one quick check today. Placed the head back on without a gasket and measured the gap between the block and head.
It was 0.06mm at various points along the front edge, the back was tight. I have access to another block so will try the same test on that.
I will also try another head on my block and carry out the same checks to see what shows up.
#30 nicklouse
  • 18,671 posts
Posted 30 April 2017 - 08:57 PM
so what is holding it up`?
water pump?
pulled top threads where the studs go in?
