Can You Bend A Wiper Mechanism Tube That Holds The Rack
Posted 17 May 2017 - 06:50 PM
Posted 17 May 2017 - 07:00 PM
Posted 17 May 2017 - 07:04 PM
Need to remount a wiper motor and it needs to be about 25mm away from its original position. just wondered if bending the tube a bit would have a detrimental effect on the rack moving inside the tube
Are you putting it inside the cabin ?
That's what I'm doing
Posted 17 May 2017 - 07:10 PM
Posted 17 May 2017 - 08:49 PM
I did this to convert a mk3 to a Mk1 and re made the flare using an 8mm die and punch
FS
Posted 17 May 2017 - 09:08 PM
Posted 17 May 2017 - 09:19 PM
Avoid any sharp bends as the motor struggles with more than a 8lb pull with the boxes on and wipers on the screen
Posted 17 May 2017 - 09:32 PM
You need to fit a mandrel inside the tube for bending or it's ID will reduce and pinch the inner rack.
Posted 17 May 2017 - 09:33 PM
Yes, they are weak as. I gave up on the standard wiper set up, they really are hopeless.
Posted 17 May 2017 - 09:38 PM
Have you found anything suitable?
I am still looking as I have messed up one bundy.
Posted 17 May 2017 - 09:58 PM
I did one a few years back. I got some steel wire rope that was a neat but not tight fit inside it, greased it, fit it, did the bend and then struggled but did eventually get the wire rope back out. Tip: don't use the fine stranded stuff, go for a course strand wire rope, the fine stuff just flattens out.
While this worked for me, I'm not convinced it's the best way forward.
Posted 17 May 2017 - 11:27 PM
Posted 17 May 2017 - 11:35 PM
What did you end up with? Suitable for a Mini?
Posted 18 May 2017 - 12:46 AM
Actually, I haven't gotten there yet with a Set up for a Mini, but is on the list.
The one's I've done are for the Moke. As ridiculous as it may sound, they are a set for a Truck / Bus. They have 35 NM Torque at the blade - enough to shift mud. I worked on the design over a few months with a company in the US who now have them as a standard design for us.
Has built in washers in the blades too!
Posted 18 May 2017 - 11:44 AM
