Well, I have seen the external springs, but using an external spring should not be fundamental, so it is possible that someone, somewhere makes a suitable internal spring. However, assuming that you can't find one, because no-one does make them, the other way is to fill the tube with low melting point metal, and heat it afterwards to drain it out. You can get a special alloy for doing it, and unlike when soldering, you do not apply flux, because you really do not want it to stick.
Or do the same with some kind of plastic. Not one that is smelly, sticky or toxic when heated, so absolutely no PTFE (MAJOR HAZARD) or PVC. A close fitting length of polyethylene rod should do the trick. A heat gun will remove it, but watch out for drips on your skin (it sticks and burns seriously, where the likes of solder tends to run off) and it may ignite if you over-do the heat. You can also use tightly packed dry sand, but you would want to do a superb cleaning job afterwards for obvious reasons.
These sort of tricks are done by modellers and such like, and I hope that one of them will work for your wiper tube. Please let us know how it goes.
Edited by tiger99, 18 May 2017 - 09:05 PM.
