Vtec Sutty ?
43 replies to this topic
#1 Sutty01
Sutty01
  • 603 posts
Posted 21 September 2006 - 06:11 PM
okay being 17 soon 18 ive found my 1293 engine is a bit on the alcoholic side so here are my few (lots) questions i hope you guys can help me clear this up ?
1.4L ,50+ dad, 17-18 on fully comp insurace £££?
Can i change the 1.4 to a 1.6 later on ?
What is the adverage cost of the convertion (parts baught to go to a workshop)?
adverage fual consumption ?
Can i keep 4 seats ?
need front end extended ?
bigger fual tank?
Filp front cost ?(standard round nose)
:dontgetit:
hope you can help
Sutty
Edited by Sutty01, 21 September 2006 - 06:13 PM.
#2 tino
tino
  • 805 posts
Posted 21 September 2006 - 06:20 PM
Get quote's from insurance companies I would expect around £300-£500 extra
Yes but its not really worth it when you can do it one go
I can't answer those question's depends on if you buy new/second hand etc
Yes
A little I think although if your careful you don't need to
bigger fual tank?
depends on if you want one :dontgetit: although I think it has to be changed
Depends on new or secondhand
#3 minidan
minidan
  • 2,354 posts
  • Local Club: LSMOC
Posted 21 September 2006 - 07:16 PM
Flip front price depends if you go , fibre glass / carbon fibre. 2 piece or 1 . etc. 1 one peice carbon front will cost about £230 i think but thats standard size. fibre glass ones are way cheaper. but then the quality may suffer.
(oh then theres fitting costs...)
#4 Sutty01
Sutty01
  • 603 posts
Posted 21 September 2006 - 07:54 PM
assume all parts are new/low milage and whats the differance between 2 peice and 1 peice it would be fibreglass.. (what are the benefits of carbon fibe outher than weight? )
Also what will i have to change 1.4 - 1.6 ?
What would the cost be to have engine and flip front fitted ?
Edited by Sutty01, 21 September 2006 - 07:55 PM.
#5 Jobu
Jobu
  • 508 posts
  • Local Club: 16vminiclub
Posted 21 September 2006 - 07:59 PM
What conversion do you want to do? As im pretty certain there isnt a 1.4 vtec engine... :D
Tell me what engine/conversion and i'll try and answer your questions :dontgetit:
#6 Sutty01
Sutty01
  • 603 posts
Posted 21 September 2006 - 08:10 PM
i could of swore i saw a thread on one... but would i still get isured with a 1.6 i mean at 17 as 2nd driver fully comp ?
are there any 1.4 engines that i can fit the same way ?
and just my previous questions.
I realy apreshiate this alot as im prity noobie to this
chears sutty
#7 Tomm
Tomm
  • 2,462 posts
Posted 21 September 2006 - 08:40 PM
ive been thinking of a 1.6 vtec conversion. It should come in around the 2K mark shouldnt it? The most exspensive part being the front subframe? at around £500 quid?
1.4 K series? I dunno sorry thats the only 1.4 conversion i can think of but i am new to engine swaps ect
#8 RacingGreen
RacingGreen
  • 2,111 posts
Posted 21 September 2006 - 08:47 PM
i think they are more like 5k and a frame is alot more than £500 when you add up all the other bits you need.
#9 Sutty01
Sutty01
  • 603 posts
Posted 21 September 2006 - 08:54 PM
ok so asuming im going 1.6 and want a relitivly new engine what should i search ?
is there a perticuar engine + subframe that go well together ?
is it expencive to use coilovers?
how much am i goung to pay for some one to do the work if i have the parts?
#10 Tomm
Tomm
  • 2,462 posts
Posted 21 September 2006 - 09:00 PM
i was looking through google for allspeed and found a site some bloke said it cose him around 2.5k and 40.5 hrs of work but i am not into these kind of cenversions so i wouldnt know sorry
#11 Jobu
Jobu
  • 508 posts
Posted 21 September 2006 - 09:01 PM
Depends on many things, and it would be a 1.6
Again would start with 1.6 on the honda conversions
Watsons will do you a conversions with engine for around £10k
With a standard 1.6 vtec 35-40mpg
Yes
Depends what subframe you use, Standard round nose conversion needs more work so probably more money for things like a custom rad, alternator brackets, ITB's or bulkhead box, custom exhaust manifold if needed etc.
bigger fual tank?
Not really needed, depends what you want really.
Standard one what people have said above. Extended one 16vminishop do a fibreglass one £220 otherwise make a metal one, cost of panels (Front panel, 4 wings or Front panel, 2 wings, sheet of metal for extension.)
There is no 1.4 VTEC engine, if you want a VTEC conversion off the shelf you'll have to use a VTEC B series engine either 1.6 or 1.8.
Look at these link:
CLICK
CLICKY
Have a read of them links, then a search on 16vminiclub should answer your questions.
Hope this has helped
Edited by Jobu, 21 September 2006 - 09:02 PM.
#12 Sutty01
Sutty01
  • 603 posts
Posted 21 September 2006 - 09:33 PM
that helped allot but is there anyway to cut down the price because 10k is way over what i can spend (2k)
#13 tino
tino
  • 805 posts
Posted 21 September 2006 - 09:36 PM
In a word NO
well not down to 2k unless you do alot of the work yourself
#14 Jobu
Jobu
  • 508 posts
Posted 21 September 2006 - 09:42 PM
Not if you want someone to do it for you, say you used an Allspeed frame which uses mini running gear your still gonna be spending £1200 for a subframe and custom driveshafts (The driveshafts are £400!) Engine mine cost £900 with EVERYTHING i needed, you could probably get one for £500-600? But make sure you get everything you need like: Engine, gearbox, driveshafts, engine and front wiring loom, ECU, gear linkage.....
to be honest i dont think you'll do it for £2000, you'll be pushed to do it for £3000 imo, mine on the engine/conversion side of things has cost about £3500.
Its not cheap lol If you want a 16v mini for cheaper go for a rover k series conversion.
Edited by Jobu, 21 September 2006 - 09:42 PM.
#15 Sutty01
Sutty01
  • 603 posts
Posted 21 September 2006 - 09:49 PM
how much of a performance drop is the k series and what is the price drop ?
