Rear Right Tail And Reversing Light Failure
electrical
7 replies to this topic
#1 Remy
Remy
  • 16 posts
Posted 26 June 2017 - 07:14 PM
I noticed the other day that my rear Right tail light had failed. So I bought some bulbs and when I went to fit it the bulb was fine. I tested it with the new and the old bulb and it didn't work either time. The reverse had blown but u replaced that and it still didn't work. Dodgy connections?
Remy
#2 spaulwill
spaulwill
  • 125 posts
  • Local Club: M4
Posted 26 June 2017 - 07:54 PM
Check the connections on the side of the holder (earth) and the terminal on both the holder (positive) have not oxidised or corroded a bit of contact cleaner or WD40 will do it remember to disconnect the battery first especially if your scraping the corrosion off. If that fails your then looking probably at a suspect earth.
#3 Remy
Remy
  • 16 posts
Posted 27 June 2017 - 06:41 AM
Thanks I'll try that later
#4 Remy
Remy
  • 16 posts
Posted 28 June 2017 - 03:42 PM
It can't be a grounding problem because the brake and indicators still work. And currently my multimeter is busted so I'm a bit stuck
#5 richmondclassicsnorthwales
  • 942 posts
Posted 05 July 2017 - 09:15 AM
Never say that, anything is possible, it's a Mini.
Earths can be good on some areas, but not all areas.
#6 Remy
Remy
  • 16 posts
Posted 05 July 2017 - 04:56 PM
It turns out it was a fuse. The dash light didn't come on so I put 2 and 2 together. Ruled them out too fast :/
Thanks anyways guys
#7 cal844
cal844
  • 9,639 posts
  • Local Club: TFMOC
Posted 05 July 2017 - 06:51 PM
Thanks anyways guys
Do you have a large exhaust fitted? Why did the fuse blow? Usually a live tracing to earth
#8 Remy
Remy
  • 16 posts
Posted 07 July 2017 - 09:10 PM
The fuse didn't go, it was the flipping connections that had corroded. And nope my car is bone stock. Thanks
