Does anyone else have a problem getting to the grease nipple with sports pack arches on?
Can i fit an angled nipple onto the rear or can a Angled adaptor be purchased?
Also what size spanner is needed to remove grease nipples?
Rear Grease Nipple Problem With Sports Pack Arches
Minigirl
, Sep 21 2017 10:03 AM
brakes
6 replies to this topic
Posted 21 September 2017 - 10:03 AM
Posted 21 September 2017 - 10:36 AM
Have a look on this link, they may be able to give you all the information you need
http://www.ebay.co.u...3-/281337017678
Posted 21 September 2017 - 12:21 PM
As in the above post I have a sports pack mini and fitted the 45 degree grease nipples and have no problem fitting grease gun now.
Posted 21 September 2017 - 05:32 PM
I don't have a problem with mine but one side is a bit tight.
I thing it depends on who fitted the arches at the factory and what he drank for lunch on that day. They seem to vary from one to the other, even on the same car... 🙄
Posted 22 September 2017 - 05:49 AM
Thanks put some angled ones on luckily the old ones came out quite easy
Posted 23 September 2017 - 08:30 AM
The angled ones are the job. Yours must have been replaced at some time or the Sportpack arch’s were a later addition.
Also tagged with one or more of these keywords: brakes
Mini Technical Sections →
Problems, Questions and Technical →
Adjusting Brake Bias For 7.5" Discs With Pdwa ValveStarted by Daniel Watkin , 16 Nov 2023 brakes |
Answered
Fam7821 Brake Limiter Valve - Mounted Upside Down?Started by tarnofsky , 29 Sep 2023 brakes |
Kent 286 Can & MotStarted by frosty90 , 07 Sep 2023 brakes |
Brake Master Cylinder ReplacementStarted by M I N I , 30 Aug 2023 brakes |
Fitting 10” Wheels On My Mini Convertible (Spi)Started by Dalla , 29 May 2023 suspension, brakes |
