Hi I have just acquired a 1380 engine it has not been run for sometime.It sounds great when running and I was wondering what CR I should expectIt is about 125 after running for about 5 minutes. I dont know anything about it except that it was built by MED. It has a 45 DCOE.Also what power should I expect ,I know it depends on lots of factors but about what should I be looking for. Thanks Bryan
Posted 30 September 2017 - 09:44 PM
Posted 30 September 2017 - 10:04 PM
Posted 30 September 2017 - 11:07 PM
As for the power output, there's almost as much chance of guessing the winning lottery numbers as there is guessing how much power you're engine will make when we have no idea of the spec.
Phil.
Edited by Turbo Phil, 30 September 2017 - 11:12 PM.
Posted 01 October 2017 - 05:50 AM
Are you saying that the compression test is giving you 125 psi?? If that is true then it is rather low. Maybe test it again when cold, then add some oil into each cylinder and test again.
Check that the valve clearances are correct.
Posted 01 October 2017 - 02:02 PM
I have a MED built engine I contacted MED via email to get some history for it as I brought it from Ebay but they were not a lot of help as they only keep the information for 5-6 years.
But they did say they did remember the engine and did tell me the timing and what carb and what year it was built.
The specs are 1380 A series block
stage 3 head
1.5 roller rockers
Duplex timing chain set at 117-118 as stated by Mini speed
omega pistons
I changed the cam as the original one was shot (old SW5) New cam-Evolution 001 from mini speed
Maniflow Manifold
Twin SU HS6 carbs (considering weber 40 dcoe)
I'll take a look at my compression I know its higher then yours as I wrote it down when I rebuilt mine.
Posted 01 October 2017 - 03:17 PM
Yes it has a number MED number stamped on the block and I like you probably because it is old they couln't tell me much about it.At the moment I am getting ready to paint the car (Reliant Robin with the engine in the back ) So when its finished I will give it a good run the retest the compression. I was told it would have had about 120 bhp when first built . By the way because the engine is in the rear there is plenty of room and it has a long kinlet manifold to a 45 DCOE carb. Bryan
engine
Mini Technical Sections →
Problems, Questions and Technical →
Spi Bad Idle And 'tapping' Engine SoundStarted by Simmi Westo , 15 Jul 2025 ![]() |
![]() Help! Water In Oil Question....Started by TerryLee , 06 Jul 2025 ![]() |
Rebuilt Engine Wont Crank With CompressionStarted by Kernreuben , 04 Jul 2025 ![]() |
1966 Mini S - Clutch IssuesStarted by MBradbury73 , 01 Jul 2025 ![]() |
Ac Dodd TuningStarted by Kevybmini , 04 Jun 2025 ![]() |
