Car Idles Perfectly But When I Put In Gear - She Jerks And Stalls
engine
10 replies to this topic
#1 postve
postve
  • 578 posts
Posted 18 October 2017 - 01:34 AM
Hello Folks,
I am new to this forum and have a problem I think I have diagnosed but wanted some thoughts.
1978 Mini
1275 engine
dual carbs
Issue:
- cars starts no problem
- idles perfectly
- when i put in gear she jerks and then stalls - just started a day ago and was running great up to this point
- If i put in second gear and drag on the clutch she will move forward slowly but as soon as a little acceleration she jerks violently and stalls
This started right after I added 94 Octane gas and want to assume maybe water in gas but not sure.
- checked the filters - dirty and replacing
- added some gas line anti-freeze - no change but thinking need to run for a while to let it mix in
struggling for an answer and last option is draining the tank and dread getting gas in my mouth.
If this does not work concerned could be worse
#2 nicklouse
  • 18,697 posts
Posted 18 October 2017 - 07:54 AM
you are going to have to elaborate this point. is it clutch drag or some other mechanical issue.
you say about second gear why? is it the same in first?
your 94 Octane is the Europe 98 Octane (or higher) so in its self  should not be an issue but over time the ethanol in modern fuels may have eaten away at some of the rubber parts in your fuel system.
#3 Spider
  • 15,143 posts
Posted 18 October 2017 - 09:49 AM
Sounds like the clutch needs adjusting or the clutch hydraulics need some attention.
#4 nicklouse
  • 18,697 posts
Posted 18 October 2017 - 11:06 AM
TBA that was my first thought.
#5 postve
postve
  • 578 posts
Posted 18 October 2017 - 11:54 AM
Thank you guys for the feedback as I am new to this awesome little car.  Previous owner had it for 15 years and kept good care of it and certainly possible clutch could be the issue.  a couple of feedback points:
  • He uses Shell 91 - no ethanol - I used 94 as only thing available at the time;
  • Problem is the same in first and second - I shift simply to see if I can move the car forward;
  • I am assuming the fact that she idles well the idea of water in gas maybe not an issue?
  • Interestingly enough in reverse no jerking or stall whatsoever?
#6 slidehammer
slidehammer
  • 1,197 posts
  • Local Club: LSMOC
Posted 18 October 2017 - 12:56 PM
If it started straight after a fuel fill up, that has got to be top on the list of things to try. Bypass the petrol in the tank and rig up a temporary feed from a petrol can (or even just fill the float bowls and see if there is an improvement.
#7 Spider
  • 15,143 posts
Posted 18 October 2017 - 05:26 PM
Sorry, but I can't see the fuel itself having much to do with this, I just think that a coincidence.
#8 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 18 October 2017 - 09:57 PM
I agree with you MS
I suspect an air leak or possibly detritus in the fuel supply pipes
Weak fuel hose/filter(which collapses under load)?
#9 1984mini25
1984mini25
  • 8,785 posts
Posted 18 October 2017 - 10:12 PM
Unless the level of the fuel in the tank before filling up was extremely low or close to empty, and in running the tank so low its allowed any dirt that would have been floating around to now be sucked up the fuel lines. Blocking any fitters (not fitted as standard on carb minis) the jet in the carb or float valve. So it’ll idle and rev fine, but underload/pulling away the carb can’t deliver enough fuel.
#10 postve
postve
  • 578 posts
Posted 26 September 2018 - 11:49 AM
Guys I am sorry for not closing this off as away on business for months - problem was the float in the SU was broken - replaced and problem solved!!
Just fixed it a month ago - thx for all the advise
#11 pete l
pete l
  • 1,379 posts
Posted 26 September 2018 - 12:40 PM
Better late than never :-)
I hate unfinished threads.
