Is This A Genuine Rover Mini Sump Guard?
34 replies to this topic
#1 Screwdriver
Screwdriver
  • 281 posts
Posted 03 March 2018 - 10:10 PM
Is this sump guard genuine?
Looks like the original Rover guard. Has anyone installed one? Do these bolt to existing mounting points or will drilling be necessary?
#2 nicklouse
  • 18,697 posts
Posted 03 March 2018 - 10:27 PM
thought the Rover ones were alloy.
#3 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 03 March 2018 - 11:04 PM
Yes you will have to drill holes, 3 at the front and one either side where the legs come to the subframe.
Never the easiest thing to fit, best done on a ramp with a gearbox jack.
#4 mk1leg
mk1leg
  • 9,343 posts
Posted 03 March 2018 - 11:18 PM
rover never fitted sump guards all were only available from spares suppliers
#5 timmy850
timmy850
  • 3,388 posts
  • Local Club: MITG
Posted 04 March 2018 - 12:12 AM
It looks the same as the one on page 21 here:
http://www.minipassi...sories 1998.pdf
Edited by timmy850, 04 March 2018 - 12:27 AM.
#6 miniireland
miniireland
  • 175 posts
Posted 04 March 2018 - 12:21 AM
Innocenti fitted these from factory
#7 wile e coyote
wile e coyote
  • 1,230 posts
Posted 04 March 2018 - 08:14 AM
Yes it is - in the "Approved Accessories" brochure from '95
Edit - oops beaten to it!
Edited by wile e coyote, 04 March 2018 - 08:14 AM.
#8 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 04 March 2018 - 08:47 AM
yes and fit an oil cooler else you gearbox will end up being toast
#9 Steve220
Steve220
  • 5,067 posts
  • Local Club: BMC
Posted 04 March 2018 - 09:21 AM
They're bloody heavy as well!
#10 Cooperman
  • 23,326 posts
Posted 04 March 2018 - 10:19 AM
That is not a very good sump guard because the angle of the front face is too vertical. When you hit a big bump it puts a big load into the sub-frame and into the front face of the guard.
The best type is the aluminium skid-type (a replica of the old 'Scottish' guard but with aluminium alloy as the plate) with steel fittings. That slides over the bumps much better.
As above, fit an oil cooler when adding a sump guard.
#11 Screwdriver
Screwdriver
  • 281 posts
Posted 04 March 2018 - 09:04 PM
Has anyone fitted the OE sump guard (not the aftermarket options) to their Mini? If so, pictures would be greatly appreciated. I'm considering purchasing one but don't like the idea of drilling into the subframe.
Edited by Screwdriver, 04 March 2018 - 09:04 PM.
#12 Cooperman
  • 23,326 posts
Posted 04 March 2018 - 09:17 PM
How does an oe sump guard fit if not by bolting it to the sub frame?
#13 nicklouse
  • 18,697 posts
Posted 04 March 2018 - 09:20 PM
to fit any sump guard requires holes drilling in the subframe
#14 Cooperman
  • 23,326 posts
Posted 04 March 2018 - 09:27 PM
And a sump guard should not be fitted unless the sub-frame is fully solid mounted.
#15 nicklouse
  • 18,697 posts
Posted 04 March 2018 - 09:39 PM
5 holes needed.
Edited by nicklouse, 04 March 2018 - 09:40 PM.
