Is This A Genuine Rover Mini Sump Guard?
#16
Posted 04 March 2018 - 10:08 PM
#17
Posted 04 March 2018 - 11:09 PM
And a sump guard should not be fitted unless the sub-frame is fully solid mounted.
uless it is just some shiny tat to "bling" up the mini and not actually something to actually do something.
#18
Posted 05 March 2018 - 12:14 AM
Personally I'm not into shiny tat or 'bling'. My sump guards are there to guard the sump from bumps and rocks. Mine is an all-welded-aluminium prototype which was produced for a major supplier, but deemed too expensive for a production item. I got it quite a while back for a very low price and it has performed very well, although it has a lot of scratches and gouges on the bottom of it. It is held on with 8 3/8" UNF bolts and spreader plates on the sub-frame. I use a 13-row oil cooler as well.
#19
Posted 05 March 2018 - 01:54 PM
Yes it is - in the "Approved Accessories" brochure from '95
Edit - oops beaten to it!
Does that make it not genuine Rover though?
More a third-party accessory you could order via the Rover dealer?
Kinda like the John Cooper performance packs?
#20
Posted 05 March 2018 - 07:28 PM
I bet it goes full length down the the gearchange mount as well.Personally I'm not into shiny tat or 'bling'. My sump guards are there to guard the sump from bumps and rocks. Mine is an all-welded-aluminium prototype which was produced for a major supplier, but deemed too expensive for a production item. I got it quite a while back for a very low price and it has performed very well, although it has a lot of scratches and gouges on the bottom of it. It is held on with 8 3/8" UNF bolts and spreader plates on the sub-frame. I use a 13-row oil cooler as well.
BMC Special Tuning supplied the only official sumpguard as far as I remember. Made from Duralloy I think, very thick, very strong and very very expensive.
We all used copies, made from sheet steel. Very heavy but saved the sump. Needed a lump of thick foam between it and the sump to reduce rock bounce damage. Oil cooler needed with one of those fitted.
#21
Posted 06 March 2018 - 12:41 AM
Mine is virtually an all-alloy replica of the original all-steel Scottish guard. It is made from 8 mm thick plate and it is all alloy with no steel at all. I can lift it with one finger but you would be amazed at the hammering it has taken in over 30 rallies. It is slightly dented and very scored, but is still a great bit of serious kit.
#22
Posted 06 March 2018 - 01:17 AM
In Japan they offered a sump guard that most of the Japanese cars seem to have. Pretty light so not sure it would do much but provide a bit of gutter protection.... Don't have a picture on me at the moment but will post if you want..
#23
Posted 06 March 2018 - 01:29 AM
my old one was a Dural "Scottish" long. going back past/to the shifter housing area.
#24
Posted 06 March 2018 - 07:47 AM
Most of the car was made by little workshops spread around the Midlands anyway!
#25
Posted 06 March 2018 - 11:40 AM
In my mind, if it's offered on the brochure, it's genuine. The real challenge I will have is fitting one.
#26
Posted 06 March 2018 - 12:08 PM
not a challenge just drill some holes.
#27
Posted 06 March 2018 - 01:56 PM
I fitted one to a rally car I was just completing a long time ago. I jacked it up, drilled the 8 holes, or so I thought, and went to fit the guard.
It was then I realised one of the holes was still just a 1/4" pilot hole, not a 3/8" clearance. I grabbed my drill, didn't put my goggles back on and got a piece of steel in my eye.
2 hours later I'm in the Lister Hospital in Hitchin where a young doctor used a needle to get the piece out! A singularly unpleasant thing to have happen.
the good news was that the sump guard fitted fine .
When fitting a sump guard it is a good idea to weld trapped nuts at the rear mounting and trapped bolts in the front edge. That way it is easy to re-fit the guard quickly for maintenance, etc. Always use 3/8" bolts or bigger. The rear mounting points which are adjacent to the lower arm mountings can be reinforced with 1/8" or 3 mm steel plates welded to the frame.
#28
Posted 12 September 2018 - 10:00 AM
after reading all of the thread it seems general consensus is not to get a square type guard, but more of a skid type one.
is the minispares scottish type any good?
http://minispares.co.../C-AJJ3320.aspx
Also would anyone happen to have the measurements of this one...I.e distance from front mounting holes back to where the side mounting holes would be?
The reason for asking is that I currently have an older minispares sumpguard, but it's the Monte Carlo one (square front).
http://minispares.co.../C-AJJ3321.aspx
It 'looks' like there might be a chance that i can use the existing holes....but not sure.
#29
Posted 12 September 2018 - 12:36 PM
#30
Posted 12 September 2018 - 02:59 PM
Hi...thanks...but was wondering whether the mounting holes on the below 2 sumpguards are the same distance away from the front mounting holes.
I've attached 2 photos to best explain.
