Battery Leakage
electrical
5 replies to this topic
#1 ERA
ERA
    Starting My Mini Up
  • 2 posts
Posted 20 June 2018 - 10:29 AM
Hello,
Could you help, I have a 1998 Mini Cooper, been in storage for 6 years and now back on the road.
I have a new battery as I thought this was faulty and was replaced by RAC, however there is a battery leakage and so I have installed a Cutout switch and a trickle charger for when it sits in the garage.
The problem is if I disconnect the charger and don't switch on the cut out switch it still drains the battery in 24 hours, not even a light on the dash panel.
Can a battery still drain if I  disconnect the Neutral?
Your help would be appreciated.
#2 cal844
cal844
  • 9,638 posts
  • Local Club: TFMOC
Posted 20 June 2018 - 12:43 PM
How old is the battery? Generally batteries will be less effective or totally dead in about 3/4 years in general use.
#3 ERA
ERA
    Starting My Mini Up
  • 2 posts
Posted 20 June 2018 - 02:46 PM
The Battery is one month old.
#4 Bat
Bat
  • 903 posts
Posted 20 June 2018 - 02:50 PM
Hi,
Disconnect the alternators big thick cable, then charge the battery disconnected from the car for 24hrs then try again.
Cheers  :proud:
#5 cal844
cal844
  • 9,638 posts
  • Local Club: TFMOC
Posted 20 June 2018 - 03:31 PM
It may have sat around for a while, I've had it where a battery was sat on the shelf at my suppliers for at least 6 months. When I'd bought it I charged it, it would struggle to start the standard A+ I had fitted.
I returned the battery to the manufacturer and requested a new built battery. It's been perfect ever since
#6 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 20 June 2018 - 11:29 PM
If its ever been left to go completely flat 0v it will never give 100% again, get the battery tested is what I'd be doing next/
