What Are Your Carb And Air Filter Combos?
22 replies to this topic
#16 carbon
carbon
  • 2,590 posts
Posted 06 July 2018 - 04:49 PM
Rally Mini 1000 - standard 1.5" SU with AAU needle and K&N cone filter
1293 Traveller - Manx spec 1.25" twin SUs with AAA needles and standard metal airbox with standard filters
Curious to know what level of power output your 1293 is running.
The AAAs can feed a lot of fuel when at top of travel. And are the HS2 internals vizarded?
#17 luismx123
luismx123
  • 525 posts
Posted 06 July 2018 - 08:42 PM
can someone explain the term "vizarded" to me? cheers :)
#18 WillCarter
WillCarter
  • 523 posts
Posted 06 July 2018 - 09:10 PM
There is a book called
"Tuning the A-Series Engine: The Definitive Manual on Tuning for Performance or Economy" by David Vizard. This is where the term comes from.
Here's a link to his book, it's definitely worth getting: https://www.amazon.c...y/dp/1859606202
Edited by WillCarter, 06 July 2018 - 09:12 PM.
#19 carbon
carbon
  • 2,590 posts
Posted 06 July 2018 - 10:12 PM
As above, the term 'vizarding' describes the modification of SU carbs to improve air flow in the quest for additional power. There are a number of stages described by David Vizard in his book including:
1. shortening the butterfly screws and thinning the throttle shaft
2. blending the carb body in the areas where dashpot piston meets the main venturi
3. streamlining the underside of the piston
4. Blending in throttle 'bridge' using epoxy or similar ramps
Vizard also usefully states that 'if you do modify your carb don't assume the existing needle profile is anything like correct'. This is worth remembering, particularly if you progress to stages 2 and 3. My experience here with HS2s suggests that:
2. blending the carb body in the areas where dashpot piston meets the main venturi will weaken mixture at full throttle high speed conditions
3. streamlining the underside of the piston will richen the mixture, particularly during full throttle acceleration
I've not yet tried the epoxy ramps...
#20 luismx123
luismx123
  • 525 posts
Posted 07 July 2018 - 08:33 AM
ah thanks for that. kinda what i was hoping for!
Any idea how much extra power one could gain from this? The mini i might be picking up soon has a 1275 with an hiff38 i believe. Used webers cost like 300pounds....or a hiff44 is fairly easy to get, but yea...
#21 Arthy
Arthy
  • 112 posts
Posted 07 July 2018 - 11:21 AM
Running a MED/ITG filter setup on twin HS4's on a maniflow inlet with my 1330. Did cut the throttle shaft/butterfly screws as per Vizard, pulls very well!
Ran these carbs for over 2 years now and has been faultless!
#22 racingbob
racingbob
  • 3,061 posts
Posted 08 July 2018 - 06:33 PM
hif44 vizard modded. med substack. itg filter. that's what's on mine very happy
#23 minitravellerman
minitravellerman
  • 99 posts
  • Local Club: Minis In Northern Ireland
Posted 09 July 2018 - 08:11 AM
I am still building the car so I've not had it on a rolling road for set up as yet. No idea of power so far - all I know is that it'll run well :)
The carbs are built to Manx spec but Mervyn Johnston (The Tollyhommon Flier) here in Northern Ireland - similar to Vizard I believe.
