Engine Won’T Start Please Help!
engine
29 replies to this topic
#16 gazza82
gazza82
  • 3,014 posts
  • Local Club: TMF+
Posted 24 August 2018 - 09:01 AM
How old is the fuel?
#17 cal844
cal844
  • 9,623 posts
  • Local Club: TFMOC
Posted 24 August 2018 - 09:37 AM
In my experience the best oil to use is 20/50 engine oil, it's what my 3 minis and my mates 5 minis run with
#18 burchy35
burchy35
  • 114 posts
Posted 24 August 2018 - 10:22 AM
Sounds very much like it's the points that have closed up. I would advise buying a Haynes manual on the mini, they have so.ple step by step instructions on many maintenance jobs like points.
It's all the fun of mini ownership ?
#19 Its a min
Its a min
  • 284 posts
Posted 24 August 2018 - 11:12 PM
Standard Points or converted to electronic ignition?
If points, have you checked to make sure they are correctly adjusted/gapped and checked the condenser.
How can you tell like I said I’m new to all of this haha
It's pretty easy to do as long as you've got a screwdriver and a set of feeler gauges.
http://minicarcare.b...reaker-gap.html
And a bit of reading which may be of help.
https://www.minimani...ng_Lucas_Points
For the condenser, check the wire isn't broken.
Good luck.
Edited by Its a min, 24 August 2018 - 11:13 PM.
#20 harrythehat
harrythehat
  • 275 posts
Posted 25 August 2018 - 06:55 AM
would be interesting to hear what the fix is as just about every angles been covered here :techsupport:
#21 The mini that could
The mini that could
  • Validating
  • 16 posts
Posted 25 August 2018 - 03:09 PM
Hello taken my carb off today which I have found out is a HS4 and the jet assembly doesn’t return to sitting flush with the bottom of the carb is that something I should be concerned about?
#22 The mini that could
The mini that could
  • Validating
  • 16 posts
Posted 25 August 2018 - 03:11 PM
#23 The mini that could
The mini that could
  • Validating
  • 16 posts
Posted 25 August 2018 - 04:31 PM
#24 The mini that could
The mini that could
  • Validating
  • 16 posts
Posted 25 August 2018 - 04:32 PM
I think it has been converted because there is a little black box where the points should be
#25 Its a min
Its a min
  • 284 posts
Posted 25 August 2018 - 05:06 PM
Sounds like it's electronic ignition so should be ok unless there's a broken wire or the module has gone.
When you say 'flush with the bottom of the carb,', in what way? Are you talking...dash pot off, needle out and looking in? If so, it's just been adjusted. Try turning the jet adjustment screw to bring it flush then give two complete turns (12 flats) down. That should be a good starting point for fuel mixture.
This will help: https://sucarb.co.uk...-tuning-general
I may have missed it but are you getting a spark?
#26 The mini that could
The mini that could
  • Validating
  • 16 posts
Posted 25 August 2018 - 06:04 PM
I was but now I’m not I’m not sure if I’ve messed something up, I’ve got the other half’s grandad coming round tomorrow to have a look at it as he has built a few mini’s in his time
#27 The mini that could
The mini that could
  • Validating
  • 16 posts
Posted 26 August 2018 - 08:40 AM
Turns out my mini has no compression in 1&2 so I think maybe head gasket?
#28 cal844
cal844
  • 9,623 posts
  • Local Club: TFMOC
Posted 26 August 2018 - 09:40 AM
Could be or a burnt valve
#29 The mini that could
The mini that could
  • Validating
  • 16 posts
Posted 26 August 2018 - 10:35 AM
Wouldn’t it be multiple valves though as it’s 1&2 instead of just one?
#30 The mini that could
The mini that could
  • Validating
  • 16 posts
Posted 08 September 2018 - 07:53 PM
Just an update for those of you that wanted to know it was the head gasket and thermostat that needed replacing
