Supercharged Bmw K Head Conversion
99 replies to this topic
#1 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 11 October 2006 - 06:25 PM
riiight i thort it was time id start a topic in here, altho im not going to start the project fully till i have some money i thort it might interest some people to know what i plan to do.
first this is what my mini used to look like(apart from a few things on there)
Attached File  DSCN1724.JPG   368.59K   19 downloadsAttached File  DSCN1725.JPG   370.08K   31 downloads
and this is what it looks like at the moment
Attached File  DSCN2315.JPG   389.77K   50 downloads
well the plans are to turbo it, and use it as a tarmac rally car i havent got a series in mind yet i thort about building the car up then finding the route.
the engine i wish to be putting in it (inshort) is a 1275 +60thou and with a long stroke crank (i had 84mm stroke in mind which i believe makes 1374?!?) i chose to go +60 rather to a bore of 73.5 because the turbo pressure and the wall width, the head to be turbo stage 4 and the cam i havent decided on.
the clutch i was going to go for a double gray but was told it damages the crank so single gray looks like the route i will choose, the flywheel will be lightend aswell.
i have read about some of the sequential dog gearbox's and im very tempted by one of these but i wil have to see near to the time of perchase :w00t: i will also have a Quaife ATB
the body im going for a colour similar to focus ST orange, carbon fibre miglia arches 10X6 wellers spaced out in black, the doors are going to be steel framed and (body coloured) CF door skin, considering a CF roof aswell
the suspension i havent decided too much on yet but front and rear anti rolebars, will be lowered a bit but not too much so i can still race about the rally stages.
protection well beee full FIA role cage with dash door bracing i also want harness tbar aswell, the seats are going to be OMP FIA aproved drive seat with helmate cage and drives identicle but without 6 point harnesses aswell
anyway thats about all i can think about at the moment, im hoping for about 150bhp and not expecting it to be kept on the road for long after compleation
Edited by mini93, 12 October 2006 - 10:15 AM.
#2 minivanman
minivanman
  • 3,454 posts
Posted 11 October 2006 - 08:41 PM
Sounds good mate. I wouldnt have thought a cf roof would be too good though if you rolled it? Have you thought bout supercharging it? I would have thought that would be better for a rally car?
#3 mini93
mini93
  • 8,615 posts
Posted 11 October 2006 - 08:47 PM
my friend mentioned to me about external waistgate...and the chatter from it
i dont think i should make my mind up again but always on the cards
#4 ed4ran
ed4ran
    Cadwell Event organiser
  • 2,849 posts
Posted 12 October 2006 - 12:10 AM
Did you mean LSD rather than LCB? or are you talking about the exhaust?
Dont think Quaife actually make LSDs, thought they were ATB diffs.
(sorry just being picky).
Sounds good though,
Although if you want a sequential dogbox they are pretty pricey :w00t:
#5 mini93
mini93
  • 8,615 posts
Posted 12 October 2006 - 10:18 AM
oops, im not used to typing that much so was kinda on auto type, i corrected to ATB thats the 1 i ment
as for the sequential, i know there very expensive so it might be a case of get everything else sorted 1st n splash out when i can do, but it would be nice quite different
#6 JetBLICK
JetBLICK
  • 1,222 posts
  • Local Club: myspace.com/worcesterretro
Posted 12 October 2006 - 03:34 PM
loving the work, i'm gonna hae to see this if ur around warwick, because im at uni in cov. Tarmac rally, dont be a pansy, get it dirty - tho where the country lanes are round here i don't know :w00t: lol
#7 steveobennet
steveobennet
  • 944 posts
  • Local Club: stu's turbo club
Posted 12 October 2006 - 10:30 PM
don't mean to call your mate a bullsh*ter but the chatter sound isn't the wastegate. it is the sound of air being pushed back through the turbo blades causing it to stall, creating that much loved chatter! although the sound is nice it is damaging your turbo and would cause premature failure. idealy you need a dump valve, which will get rid of the chatter and prolong the life of your turbo. external wastegates are really needed unless your puching serious power (400+) even then they are a bugger to set up properly. just my 5p worth
#8 mini93
mini93
  • 8,615 posts
Posted 12 October 2006 - 10:51 PM
i know about the chatter caused by the air passing back through the tubine blades but im not entierly sure ether but he mentioned u can still get same noise from external...tho im not sure if i got wrong end of the stick anywho im not goin about to damage my turbo so dumpvalve it is then, defo would have been nice tho! aaah well
also dont worry i dont want to be pansy with the tarmac stages also light gravel, u know with the corner cuts over the country roads (sparks flying from sumpgaurd etc :w00t: )
Edited by mini93, 12 October 2006 - 10:56 PM.
#9 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 13 October 2006 - 07:22 PM
CF roofs are a big no no unless you have a A FULL roll cage + more shell strengthening!!
also you will have to fins a way of bonmding it in place with out it looking arse, they are a notoriously bad fit,.. and this is because they are designed to for RACE USE ONLY! they are foten bolted down so they are removable.
not crushing your plans dude, but it's a lot of bother to go to when you could spend your money much better else where i.e. engine and suspension!! i really wouldn't recommend it.
#10 mini93
mini93
  • 8,615 posts
Posted 13 October 2006 - 07:32 PM
well i am gona be using it for race im not fully deided on the CF roof anyway i dont spose anyone knows of the weight saving?
its also defo' gona have full rolecage also mounting to A and B pillers
#11 mini93
mini93
  • 8,615 posts
Posted 17 January 2007 - 09:05 PM
hmm, seems like iv changed my mind, and have for for a while now....the new plans mean the name of my topic should change....if a mod could change it to "tarmac rally mini" that would be ace :gimme: thanks
anyway the new plans, jeez where to start its gona cost a bit more i expect...basicly i want it to now be supercharged.
i was kept up all night thinking about what i could do to my mini and iv decided that it will be:
Block ether a 1384 or 1420 block or somthing like that i wanted a stroked engine as i believe this will create alot of torque nice for acceleration needed in motorsports,
Head is going to be an 8 port, which will mean alot of custom work will be needed to get the supercharger running to the ports
Fueling running throttle bodys connecting to each port on the head
Ingnition/Electronics will be running an ECU to controle the amount of fuel entering the engine also will be used to controle the spark ignition
Bottom End This is staying as i wanted before with sequential box and LSD/ATB
Body The body im now again thinking about keeping it white but am not sure, iv decided i dont realy want to go for carbon fibre arches anymore with wide split rims as a believe that they will just get trashed with the strones from the road being flicked at them, definatly keeping the steel roof for saftey reasons
if theres any sujestions from people please dont hesitate to add anything, this is going to be one hell of a job so will be taking a bit more time than i thort for the turbo project
#12 CanadianMiniFan
CanadianMiniFan
  • 1,591 posts
Posted 18 January 2007 - 01:20 AM
Sounds like a sick mini....ur rihgt keep the exterior stockish, at least keep it cheap cuzz it'll get trashed by gravel....good to see someone going for the real world rally look.
#13 Pie
Pie
  • 7,695 posts
  • Local Club: GoGoAuto
Posted 21 January 2007 - 03:40 PM
13x7 weller wheels?? in black?? or the white ones, theres a few nice sets going on ebay at the moment.
#14 mini93
mini93
  • 8,615 posts
Posted 22 January 2007 - 01:38 AM
nope 10X6 wellers, referbished 1 just before my engine went i was going to sell them as i wanted splits but they would also just get trashed, steel wellers ill be able to upkeep quite easily if they get bent just chuck em n jump on egay
#15 mini93
mini93
  • 8,615 posts
Posted 12 February 2007 - 12:14 AM
this is basicly my list of stuff i need to buy, a shorted one course theres still lil' bits ill need to buy before i get round to racing, but this will give a basic idea of everything i would hope, theres also lil bits that i need to erase off the list due to other plans like im probably going to use coilovers
1. 8 port cylinder head
2. Cam shaft- supercharger friendly
3. engine block 73.5 (1380)
4. low compression pistons
5. supercharger
6. charger kit
7. ECU
8. charge cooler
9. ignition system (DIS, trigger wheel etc)
10. Stroked Crankshaft- knife edged, wedged, cross drilled and Ni-tempered
11. throttle bodies
12. 4 Branch manifold
13. maniflow exhaust system
14. Steel centre main strap:
15. oil pump
16. Con rods
17. ARP head studs & con rod bolts
18. Duplex timing gears
19. Ultimate engine steady
20. Shift light:
21. Rev limiter:
22. Lightened flywheel:
23. Clutch assembly-double grey, comp spring, sintered:
24. sequential dog box
25. Limited slip diff’ & hardy splicer drive shafts
26. Oil cooler kit
27. Central oil pick up pipe
28. Braded clutch hose
29. Performance spark plugs & HT leads
30. Fuel pump- high flow pump
31. Competition battery:
32. Samco hoses:
33. Rally steering wheel and boss kit:
34. RAC sump guard extension:
35. Braded brake hoses:
36. 4pot calliper set: not inc. disks/ pads or VAT
37. Competition brake shoes:
38. Magnetic extended sump plug:
39. Minifin brake drums:
40. Fly off handbrake:
41. Solid subframe mounts
42. Shock absorbers:
43. Competition cones:
44. top shock mounting (comp)
45. Uprated bottom arm pin
46. Rear camber brackets:
47. 2 deg lower arms
48. Locking wheel nuts:
49. Rolecage:
50. Perspex windows:
51. Bucket seats & mountings
52. Harnesses:
53. Gauges- oil temp, oil pressure, voltmeter & ammeter:
54. Alloy race fuel tank
55. Carbon fibre bootlid:
56. Carbon fibre door skins:
quite a list realy
