Indicator Lights Not Flashing (1995 Mini)
electrical
9 replies to this topic
#1 Marcel's Owner
Marcel's Owner
    Starting My Mini Up
  • 3 posts
Posted 13 September 2018 - 04:30 PM
I have a French 1995 Mini Seaway, the indicators started off working when I first brought the car. But had become inconsistent. They are not not working at all. Any advice?
I have read about a flasher unit, is this in a 1995 Mini.
First Time Mini owner in need!!
#2 Bat
Bat
  • 903 posts
Posted 13 September 2018 - 05:09 PM
Hi,
Welcome!
Do the hazard lights work?
Cheers  :proud:
#3 Marcel's Owner
Marcel's Owner
    Starting My Mini Up
  • 3 posts
Posted 13 September 2018 - 05:10 PM
Hi,
Welcome!
Cheers  :proud:
Yes they do.
#4 matt615
matt615
  • 923 posts
Posted 13 September 2018 - 06:26 PM
I’d suspect a bad connection somewhere. Primary suspect would be the fuse box. The spade connectors and the ends of the fuses can become dirty and corroded, causing problems like this.
#5 matt615
matt615
  • 923 posts
Posted 13 September 2018 - 06:29 PM
Also faulty hazard light switches can cause this problem. As well as turning on the hazards they cut power to the indicators (so you can’t cause problems by having them both switched on at the same time.
Even if the hazards work, the indicator cut off function of the switch could be faulty.
Sometimes the problem can just be dirty connectors on the back of the hazard switch.
#6 RedRuby
RedRuby
  • 1,201 posts
  • Local Club: No
Posted 13 September 2018 - 06:57 PM
I had a fault with mine recently turned out to be a Relay. Don’t know the configuration of yours but if you look under the bonnet on the left hand side near the bulk head you probably have two relays. If you do the one nearest you may be for the indicators, it is on mine a 93 SPi, the one furthest away I think is the horn relay if you swap them over and your indicators work problem solved, new relay required, if not then flasher unit, fuses, hazard switch.
Edited by RedRuby, 13 September 2018 - 06:58 PM.
#7 Marcel's Owner
Marcel's Owner
    Starting My Mini Up
  • 3 posts
Posted 14 September 2018 - 02:47 PM
Thank you. I will try these out.
#8 MikeRotherham
MikeRotherham
  • 1,031 posts
Posted 14 September 2018 - 06:05 PM
I had exactly the same problem and reseating the relay cured the problem.
#9 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 14 September 2018 - 07:27 PM
Try removing and cleaning the terminals on the relay, failing that replace it
#10 Ethel
  • 26,818 posts
Posted 15 September 2018 - 12:16 AM
Later Minis have one electronic flasher that works  hazards as well as indicators. A relay is switched by the ignition circuit to connect the flasher to the indicator stalk. The fault could be at the relay, the hazard switch or the stalk.
