Mini Wont Start But Will Run W/bump
electrical
Best Answer cal844 , 09 October 2018 - 08:26 PM
Test for power at the white/red on the solenoid (if not it will be the ignition switch)
If there is power on the above then check that the solenoid is earthed to the inner wing(clean, shiny metal on the solenoid and wing) then check the boot floor to battery terminal earth Go to the full post
15 replies to this topic
#1 03matherb
03matherb
  • 10 posts
Posted 09 October 2018 - 06:06 PM
hi all
First experence on a mini forum, hope these are still active ha
Ive had my 'mk3 1971 mini' 6yrs now and fixed everything myself (with help from youtube and haynes ha). but this one has stumped me!?
ignition light comes on but she wont start!? ive replaced the starter solenoid, checked all cabels n connectors are secure, headlights are full power (which i assume shows battery isnt dead/dying)
it has electronic 'points'!?
when i turn the key there are no clicks or sounds!?
but will run with a bump/push start!?
any ideas
thanks
Edited by 03matherb, 09 October 2018 - 06:17 PM.
#2 cal844
cal844
  • 9,638 posts
  • Local Club: TFMOC
Posted 09 October 2018 - 07:26 PM
Is it a pre engaged or inertia starter? (Is the solenoid on the starter or inner wing)
I'd say the starter solenoid is shot
#3 paul748
paul748
  • Just Joined
  • 80 posts
Posted 09 October 2018 - 07:27 PM
Assuming battery is OK?
Check the earth straps from engine to bulkhead. That's the negative connection for the starter motor and solenoid. If resistance is too high due to corrosion it will not turn over.
#4 paul748
paul748
  • Just Joined
  • 80 posts
Posted 09 October 2018 - 07:29 PM
 Or this :D
#5 Spider
  • 15,077 posts
Posted 09 October 2018 - 08:03 PM
Check that when you turn the key to the start position, you are getting power to the Solenoid on the White / Red wire.
If yes, then solenoid, if no, then possibly the ignition switch.
#6 03matherb
03matherb
  • 10 posts
Posted 09 October 2018 - 08:05 PM
i thought starter solenoid aswell, new one came today, fitted it and no change!?
its a solenoid on the inner wing type.
starter motor wa new 1yr ago, nt that that means owt ha.
will check earthing contacts now, i assume ya mean the one from the battery to the body?!
#7 03matherb
03matherb
  • 10 posts
Posted 09 October 2018 - 08:10 PM
ive been had ignition switch mentioned at work, what is that exactly!?
is it on the stearing collum/barrel, because i had a loose brown wire there that wa hanging out of its crimped connector, i re crimped a new connector and connected that back up, to no avail!?
i need to turn key and test if theirs power at solenoid as well then!?
#8 cal844
cal844
  • 9,638 posts
  • Local Club: TFMOC
Posted 09 October 2018 - 08:26 PM   Best Answer
#9 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 09 October 2018 - 08:30 PM
Where about in Yorkshire are you? always willing to give some help and advice, if you are reasonably local
and struggling .
#10 03matherb
03matherb
  • 10 posts
Posted 09 October 2018 - 09:13 PM
ARRRRRR i think Cal has hit nail on head its hanging loose i noticed other day it had come loose from its screw/bolt on wing, i didnt know it had to be earthed itself, gunna reattach it now, in dark haha
i live in darton now, nr barnsley, spraybeater
#11 03matherb
03matherb
  • 10 posts
Posted 09 October 2018 - 09:25 PM
What a beat cal844, summot so simple, ive just made a wire wi croc clips, earther the solenoid n perfect.
i thought solenoids worked like a switch, just opening n lettin power trough, n the bolts are so small i assumed they wer there just to hold it in place!?!?!
FIXED thank you all for your help am going to be more active on here now :D
she just needs a bit of tlc n a new bonnet n ill love her again haha
i wa ready for scrapping her hahaha
#12 cal844
cal844
  • 9,638 posts
  • Local Club: TFMOC
Posted 09 October 2018 - 09:33 PM
If you ever have starting issues check that the solenoid is earthed. A friend and I have both had rust build up between the solenoid and inner wing.
A good clean with 40 or 80 grit sandpaper until shiny, then I give the cleaned areas a clean with brake clean or degreaser to remove the dust
#13 03matherb
03matherb
  • 10 posts
Posted 09 October 2018 - 09:41 PM
will do, when i got it resprayed 2 yr ago, they did engin bay aswell n thats sized them bolts solid so i need to cut them n fit it to the wall with new bolts rly
thanks pal
#14 cal844
cal844
  • 9,638 posts
  • Local Club: TFMOC
Posted 09 October 2018 - 10:14 PM
On my estate the inertia type starter is held in with two large screws and dzus clipped in the wheel well
#15 johnyj
johnyj
  • 66 posts
Posted 10 October 2018 - 11:41 AM
That is an interesting piece of information and something i did not know. I will have to look at mine before i try starting it as the last owner said he could not get it to run
