Let the Butchering Begin
274 replies to this topic
#76 mighty_mini
mighty_mini
    Sambo Spoon
  • 2,499 posts
Posted 14 May 2007 - 11:51 PM
a pictureless update im afraid, i will have to get some tomorrow.
Today i went down the workshop and did some welding that ive been putting off for a few days.. There was a hole in the wishbone. I would have replaced it but even with a breaker bar it wasnt coming undone easily and i was more worried i could snap the bolt and ruin the subframe in some way.
Now both driveshafts are in, the hubs and Gaz shocks are on too. I ended up using the rover 400 brakes so theyre vented as standard and the calipers are larger than the Gti units. Win!! I made a little more adjustments for the gear selector, which now works perfectly. The selector comes though the bulkhead and mounts to the top of the Exhaust tunnel. With the selector out the way i aim to get the exhaust right in the tunnel so theres nothing to really hit whilst messing around on rough terrain etc.
Im currently (12:45am) sorting the ford edis wiring out as i type this. Soldering the loom and heatsrinking the joins. I want to start on the wiring of the ECU so that i can get it up and running in the next week. That means i can get to work on a base map and stop being worried that i wont have time to map it before germini.
My first job tomorrow will be mounting the EDIS triggerwheel and VR sensor to the crank. Ive got a rough idea how im going to do this.. but we'll take it as it comes...
On a lighter note, i nearly bought a 50hp nitrous kit.. but realised that shít is for whimps and straightline pimps..
Im beggining to wonder if 150hp is really going to be enough.... :)
#77 CanadianMiniFan
CanadianMiniFan
  • 1,591 posts
Posted 15 May 2007 - 02:47 AM
tuuuuuuuuuurbooooooo, that's the way forward.
#78 Purple Tom
Purple Tom
  • 4,921 posts
Posted 15 May 2007 - 07:55 AM
Looking really good Dave. I've seen a few MS kits built up now and they seem so simple. I think when I finally go to 16V I'll be running the same system on the Vauxhall engine.
As for 150bhp being enough, I think it more than likely will be. At least for a year anyway! The thing about the bigger lumps is not so much the power but the torque. When there's that much in a Mini the power figure doesn't matter quite so much. I'm starting to get a bit bored of the C16SE with around 105bhp and 110lb/ft but it doesn't take much to release a few more ponies! I don't know what torque yours will be making but in a light van it'll just be silly. I for one can't wait to see it!
#79 Pie
Pie
  • 7,695 posts
  • Local Club: GoGoAuto
Posted 15 May 2007 - 12:18 PM
Dave as tom said, it will be fine at least for gerMINI, then in winter you can stick a supercharger on it :) LMAO
#80 ~yello~
~yello~
  • 203 posts
Posted 15 May 2007 - 12:22 PM
you'll only blow something up if you try and make it more powerful :)
#81 mighty_mini
mighty_mini
    Sambo Spoon
  • 2,499 posts
Posted 15 May 2007 - 01:35 PM
Woman! Know thy place!
Edited by mighty_mini, 15 May 2007 - 01:35 PM.
#82 mighty_mini
mighty_mini
    Sambo Spoon
  • 2,499 posts
Posted 16 May 2007 - 04:04 PM
Today was a good day...
I went down the workshop to start fitting in the loom. Although i had a few visitors come round i made some nice progress before i had to come home.
No bodging here! All solder and heat shrink :(
*phone pics, batts dead in cameraaaraaaraaraa*
#83 mighty_mini
mighty_mini
    Sambo Spoon
  • 2,499 posts
Posted 17 May 2007 - 08:16 AM
*packs up*
Later folks.. im off down the workshop... ^_^
#84 TimS
TimS
    Mini Doctor
  • 2,712 posts
Posted 17 May 2007 - 09:08 AM
Yey Dilly has an engine sat in here again! Hope you have some charged batteries today Dave... im looking forward to seeing some pics.
#85 mighty_mini
mighty_mini
    Sambo Spoon
  • 2,499 posts
Posted 21 May 2007 - 03:37 PM
Here are a couple snaps of previous work done...
Here is what i like to call the "live wire loom"... basically its just the circuit for feeding the required amount of power to each item that needs 12v. For instance the Megasquirt only needs 2Amps, the Fuel pump needs 10Amps, the injectors and O2 only need 5Amps and the EDIS 20Amps
I divided them up into 3 pairs..
Megasquirt and EDIS
Injectors and O2 Sensor
Fuelpump and Cooling
All fused individually as you'd usually see in cars.
The engine wiring was pretty simple once it was laid out. It was just a case of Soldering and heatshrinking each join.
First boot of MS2 was with the "bootloader" jumper on. This way i am able to upload the latest firmware to the ECU. THis took approximatly 10seconds to update. :thumbsup:
Unfortunatly, I cannot connect to the ECU to map anything as yet. There is a software issue with one of the .INI files linked to the software. I have to edit it to make it expect the right firmware version from the ECU.
#86 Pie
Pie
  • 7,695 posts
Posted 21 May 2007 - 06:42 PM
WOOOoooooooooooooo
go dave! looks like you had a fun day. How many times did you burn your hands whilst soldering??
Also ill send you a PM, to let you in on a little secret :-
#87 Alburglar
Alburglar
    Das Pingu's
  • 3,332 posts
Posted 21 May 2007 - 07:18 PM
looking good dave. I've still got that 1.8 crank if you want it.
#88 mighty_mini
mighty_mini
    Sambo Spoon
  • 2,499 posts
Posted 21 May 2007 - 11:32 PM
AL, ill pm you :-
#89 mighty_mini
mighty_mini
    Sambo Spoon
  • 2,499 posts
Posted 06 June 2007 - 03:59 PM
Ive been pretty slack with updates recently.. so much so that ive got about 60pics to sort through so far ;D So quickly, here is a pic of what ive been up2 recently Posted Image
Pikey spec pedal box isn't it...
Edited by mighty_mini, 06 June 2007 - 04:00 PM.
#90 Jammy
Jammy
  • 25,397 posts
Posted 06 June 2007 - 05:27 PM
That should make heel and toe a bit easier! ;D
