Spi/mpi 99 Rover Stalling When Throttle Pressed
#16
Posted 25 February 2019 - 03:52 PM
#17
Posted 25 February 2019 - 03:55 PM
I'm jealous ... I did a week kayaking around the Desolation Sound area a couple of years ago, you live in a great part of the world!
Stu.
#18
Posted 25 February 2019 - 05:52 PM
Hi there is free diagnostic software available:http://www.theminifo...-reader/page-11
as well google for mems-diag and mems-gauge. All you need is a 5V usb-ttl converter and the conection to your car.
You may diagnose if your map sensor , and temperature sensor work as well as if your IAC is working and a lot of other things.
#19
Posted 27 February 2019 - 12:12 AM
#20
Posted 27 February 2019 - 01:30 AM
Few garages would be able to fix any car with an ECU without having at least a basic diagnostic reader.
Replacing the Vac Pipes and the Stepper MIGHT fix your problems, but maybe not. That could be more money down the shute. A Sykes Pickavant ACR4 (there's one or two others) could be a good investment if you want to keep the car for a while.
And Vac Pipes changes, sensor changes and stepper changes are very DIYable.
#21
Posted 27 February 2019 - 03:46 PM
https://www.ebay.com...ogAAOSw5UdbWGbc
Or should I try this
https://rover.ebay.c...tm/283394025396
Edited by Turch09, 27 February 2019 - 05:35 PM.
#22
Posted 27 February 2019 - 04:59 PM
@Wiggy
Hi what is a Pickavant ACR4 able to do more than free software?
Even the mems-diag can do logs. ( yes it is a bit tricky to export it but it is possible).
Without a logfile you have to decide immediately where or what the fault is.( If you are a professional working in a garage with a lot of expierence it is ok)
with a log file you may diagnose later and ask other people who are faniliar with that car and its faults.
Or do you sell them?
#23
Posted 27 February 2019 - 06:07 PM
#24
Posted 27 February 2019 - 06:41 PM
@Wiggy
I've no idea. I don't have an SPi, I have an MPi. And the free software doesn't work with MPi. So I can only comment on what I've used.
#25
Posted 27 February 2019 - 08:36 PM
Hi Turch09,
can you do do it yourself work? Do you have laptop, tools to work on the car? Familiar with welding jobs, do you have a voltmeter and are familiar with it?
Have a look to your TBI unit. Have somebody switch on and off the ignition.There should be a noise from the stepper motor and the butterfly should move slightly. If not take the tbi apart and have a look to the stepper motor.TPS should regulate between 0,5 and 5 Volt.
By the way, unplugging TPS will not hurt engine, engine will run in limp mode and run very lousy with a high fuel consumtion. In worst case your catalytic converter will die!
#26
Posted 28 February 2019 - 07:07 AM
and of course read this:http://www.theminifo...oint-injection/
Edited by genpop, 28 February 2019 - 07:18 AM.
#27
Posted 28 February 2019 - 08:00 AM
What ECU does this car have ? the 2J MPI one ?
What diagnostics plug do you have ?
#28
Posted 28 February 2019 - 08:03 AM
If you have the MPI diagnostics plug then you could get one of these.
https://www.aliexpre...sAbTest=ae803_4
I have one and have compared it to a T4 that I now have and the readings are identical.
