Rear Knocking Noise
20 replies to this topic
#16 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 22 August 2019 - 04:53 PM
On the rear shock uppers there are 2 bushes, each has a cupped washer either side of them. I removed the inners cups so the rubber mounts directly to the arch.
By doing that I suspect the rubber bush will deteriorate faster than usual
#17 GraemeC
GraemeC
  • 7,467 posts
Posted 22 August 2019 - 05:02 PM
Why do you think that?
#18 Steve220
Steve220
  • 5,115 posts
  • Local Club: BMC
Posted 22 August 2019 - 06:01 PM
Standard on a lot of others shock set ups. I'm fine with it deteriorating faster, it doesn't knock anymore which will be causing metal fatigue.
#19 Bobbins
Bobbins
  • 1,525 posts
Posted 22 August 2019 - 09:11 PM
Makes sense now, thanks.
#20 Bobbins
Bobbins
  • 1,525 posts
Posted 22 August 2019 - 09:47 PM
Also the same setup as the front tie rods which don't have intermediate washers.
#21 Tallguysmallcar
Tallguysmallcar
  • 27 posts
Posted 23 August 2019 - 08:17 AM
Thanks! I left the washers in, just had to torque up the upper bolts. Pain in the royal bottom as fuel tank had to be removed, well worth it though. Just realised that the engine steady bushes desperately need replacing too...
Thanks again for your help.
