Just been out to car. Now won't turn over. Will disconnect battery tomorrow leave off while I refix bonnet switch wire. ECU plugs are clicked into place cant be pulled out without releasing lugs. Will get new quality fob batteries synchronise them to car and start over.
Jime 17 has a point, even though car battery is new also will jump from a slave to get it spinning.
Snap of the earth point will be good. A mechanic friend took out the main wiring loom to the ECU etc when he lifted the engine for me. There did not seem to be any connectors left over when I put it back on restoration but will locate earth point to make sure connections are solid.
thank you all up to now for your help.
