Back to basics I've just checked and rechecked all the wiring and connections on the engine management loom. Only thing I can determine is that coming out of the black multi pin ECU plug I've got a single black 4mm thick wire that I've connected to a nut and thread terminal on the starter assuming that was an earth connection (its opposite the one with the positive feeds that has three wires going to it) in between the two terminals is a spade connection. Consulting the Haynes manual it seems I've got the latter ones right as the starter turns over.
The single black wire mentioned above looks similar to the one in wiggys first picture that is earthed to the side of the servo. The old method of putting nuts and bolts back into places as an aide memoire for reassembling seems to have worked as I've also got a single bolt in a captive thread that is finger tight.
I cannot see any other unconnected wires so will take it off the starter and earth it to the point in wiggys pic.
Off we go
