Su Hs4 Carb (Car Cuts Out)
engine
5 replies to this topic
#1 morris13
morris13
    Starting My Mini Up
  • 2 posts
Posted 10 June 2019 - 07:53 PM
1275 engine (1994) and SU HS4 carb all installed last week and I’m having trouble keeping my car alive.
After about 35 seconds or so the car dies, irrespective if she’s running lean or rich.
Any ideas or suggestions would be greatly appreciated.
if needed I have a video that I can throw up somewhere to show you guys what going on and maybe you could confirm my set up it all correct.
#2 morris13
morris13
    Starting My Mini Up
  • 2 posts
Posted 11 June 2019 - 01:19 AM
the car starts fine, sputters even when giving it gas, shakes and dies
#3 unburntfuelinthemorning
  • 1,990 posts
Posted 11 June 2019 - 06:28 AM
The video would help.  Could be flooding or fuel starvation due to float chamber problems.
#4 nicklouse
  • 18,697 posts
Posted 11 June 2019 - 07:19 AM
what needle? what spring? etc is fitted to the carb
the HS4 was fitted to many cars and engines.
#5 Its a min
Its a min
  • 284 posts
Posted 11 June 2019 - 12:06 PM
Hi morris13
I've just had similar problems but mine struggled to start. Once started, it did exactly as your's seems to be doing. I ended up spraying some carb cleaner, with the straw attached, down the jet hole from inside the carb and it looks like there may have been some crud restricting fuel flow. Obviously had to clean the float bowl out afterwards but now starts and runs.
Also, check for air leaks. I found I had a slight leak around the butterfly spindle on one side but I don't think this shouldn't stop it from running, just make it difficult to get it running smoothly.
I hope this helps and good luck.
#6 kiwimike01
kiwimike01
  • 53 posts
Posted 19 June 2019 - 07:23 AM
had a similar issue mine and my problem turned out to be the carb wasnt tightened to the manifold enough. i replaced the gaskets and got new screws to tighten it fully and have no more issues. maybe worth a check
