Swiftune Distributor: Right Curve For Kent Cam 266
engine
5 replies to this topic
#1 DerPhilipp
DerPhilipp
    Starting My Mini Up
  • 2 posts
Posted 04 August 2019 - 04:12 PM
HI, I'm the new one. :-)
44 years old, for 22 years a mini is part of our family. At the moment it's a Mini Van from 1968.
The mini has got a built up engine identical to the MG Metro engine.
  • Engine size: 1293cc
  • roller tip rocker 1.5 ratio
  • modified cylindre head with
  • Valves: 36mm x 30mm
  • compression: 10,2 : 1
  • Distributor: Swiftune 59D non vac
  • cam shaft: kent cam 266
  • fuel: 98 octane
From a friend of mine I bought the Swiftune distributor.
The engine is running but I'm not sure about the exact ignition curve (of the 16 possibilities). I already asked at swiftunes, they recommend starting with the large bore road and track day curves first. But I'm afraid of destroying something..
My favorite curve would be number #11... and I'm looking for a curve similar to aldon yellow.
I also already searched through the forum, but still am not sure which one to take...
Would be great if you could help me, please tell me, if I have to deliver further details..
:gimme:
See you at the IMM.
#2 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 04 August 2019 - 05:48 PM
My guess would be curve 13 or 14, but dialled in at 8 degrees at idle with the vacuum disconnected. Then reconnect once set
Ac
#3 carbon
carbon
  • 2,590 posts
Posted 04 August 2019 - 06:12 PM
Would suggest the following:
- about 13 degrees static advance
- about 23 degrees advance by 1250rpm
- max 33 degrees total advance by 3000rpm
this is with Maniflow freeflow and RC40 twin box exhaust system
#4 DerPhilipp
DerPhilipp
    Starting My Mini Up
  • 2 posts
Posted 05 August 2019 - 05:12 PM
Thank you for the fast answers!  :thumbsup:
@ACDodd: I'll try out curve 13 and 14. The Swiftune installation guide said the dynamic adjustment should be set at 10 degrees. Should I set it on your advice (with 8 degrees) nevertheless?
My distributor doesn't have a vacuum..
While searching through the internet I found a timing curve supposedly from an aldon yellow, which confused me completely:
1000 - 2°
1500 - 8°
2000 - 17°
2500 - 20°
3000 - 22°
3500 - 24°
4000 - 25°
4500 - 27°
above 5000 - 28°
Are these dates right, I thought they'd correspond with a different curve.
Many questions, sorry, but I'm afraid to crash something.  >_<  And thanks once more.
#5 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 05 August 2019 - 05:27 PM
I said 8 for a reason, so yes set it at that.
Ac
Edited by ACDodd, 05 August 2019 - 05:28 PM.
#6 croc7
croc7
  • 817 posts
Posted 06 August 2019 - 02:41 PM
My engine is close to yours but a 1360 and I have my Swiftune set at #15, 10 degrees at idle. Runs very well. Experiment a little to find the best for your application, play with the mixture-you will find what works best.
