96 K1100 Equinox
124 replies to this topic
#106 johnR
johnR
  • 2,297 posts
Posted 15 May 2021 - 12:34 PM
Why not on the other side, below the alternator?
or on the offside inner wing - over the (redundant?) air scoop hole?
#107 72hump
72hump
  • 200 posts
  • Local Club: IMOG
Posted 15 May 2021 - 08:54 PM
Is the starter the issue or is it the flywheel housing it fits to? I filed a good chunk of the housing off so it is flush with the starter to get mine to fit in that place.
I decided to leave the cooler off for now, I will fit it if I have cooling issues but if not will leave it off, easy to add in though as I've built the car with it being fitted in mind.
Probably going to do what your going to do, but I want to get it fitted somewhere for the time been, just so I'm happy everything fits, and more importantly that it works.
It's to big to fit in there Graeme.
Still a bit tight in there John, with the cooling fan mount, and it would pickup quite a lot of crap from the road.
#108 GraemeC
GraemeC
  • 7,438 posts
Posted 15 May 2021 - 09:19 PM
I’ve the same cooler and a bigger alternator and it fits, and have previously had a 13 row in there.
Admittedly I’ve flattened the lip on the front panel like the MPi
#109 72hump
72hump
  • 200 posts
  • Local Club: IMOG
Posted 15 May 2021 - 10:26 PM
Yeah it might fit on a standard mini engine, but the problem that I have is that the sandwich plate thermostat sticks out, and the fittings fowl with the throttle body filter, it's my ******* up, so I'll find a way, don't really want to start cutting into the body work as the car is sprayed.
#110 72hump
72hump
  • 200 posts
  • Local Club: IMOG
Posted 02 August 2021 - 10:30 PM
Things have been very slow on the mini front, between work and the garden, there hasn't been much progress. Might have resolved the oil cooler position, will try and get some pictures post over the next few days.
Had to strip the cam pulley cover off, as I had a small weep from the gasket, cleaned it up and put RTV sealant on this time, seems to be ok now.
Cheers Paul.
#111 72hump
72hump
  • 200 posts
  • Local Club: IMOG
Posted 04 August 2021 - 07:12 PM
Well, as you can see from the picture, the oil cooler is in pretty much the same position as I had it, but with a few tweeks. I've turned the ITG filter upside down to give me more room to turn the cooler with the fittings at the top, and modded the left hand bracket so the fitting on the top left does not clash with the body work. I've still to weld the brackets up, drill a few holes, etc, etc. Once all that finished of, I'll give the brackets a coat of chassis black.
Attached File  image.jpeg   69.87K   4 downloads
#112 IronmanG
IronmanG
  • 1,233 posts
  • Local Club: Box hill. Lsmoc member
Posted 04 August 2021 - 07:31 PM
What bonnet are you running to fit that filter under
#113 72hump
72hump
  • 200 posts
  • Local Club: IMOG
Posted 04 August 2021 - 08:07 PM
Just running with the standard steel bonnet with modifications!
#114 72hump
72hump
  • 200 posts
  • Local Club: IMOG
Posted 20 August 2021 - 08:10 PM
Just a wee up date today.
Made up the flexiable brake lines for my KAD brake bias pedal box.
Attached File  image.jpeg   58.44K   1 downloads
Attached File  image.jpeg   58.67K   1 downloads
Finally sorted the throttle cable bracket.
Attached File  image.jpeg   56.32K   1 downloads
Oil cooler topped up and fitted into place.
Attached File  image.jpeg   66.03K   0 downloads
That's it for the time been.
Paul.
Edited by 72hump, 20 August 2021 - 08:13 PM.
#115 72hump
72hump
  • 200 posts
  • Local Club: IMOG
Posted 16 January 2022 - 03:22 PM
Hi guys, not much has really happened with my car since August, work, life, and house/garden stuff keep getting in the way of progress, lol. Here's a few pictures of what I have managed, which is not a lot really!
When is the next IMM in the UK going to be, lol.
Oil catch tank fitted under the off side wing.
Attached File  image.jpeg   65.37K   0 downloads
KAD brake bias fitted and plumbed in.
Attached File  image.jpeg   50.88K   0 downloads
Finally fitted the alloy stalk ends on which I got from one of the lads on here.
Attached File  image.jpeg   58.53K   4 downloads
Made up a mounting bracket for the SC FPR.
Attached File  image.jpeg   40.61K   0 downloads
Before fitting in the braided fuel lines.
Attached File  image.jpeg   56.59K   1 downloads
I have fitted all the new coolant lines to the heater, but forgot to take a picture, it was a bit of a PITA due to getting everything to fit and to make sure it flows in the correct direction, which was done with a check valve.
Anyway, that's it for a while, as once I get back from work, I've got a new window to put, decking to finish, start on remodelling the bedrooms, and on suite to start to top it off!
Cheers for looking Paul.
#116 72hump
72hump
  • 200 posts
  • Local Club: IMOG
Posted 27 August 2023 - 04:53 PM
Hi guys, unfortunately not been up to much with mini over the past year, now that IMM 2025 has been announced, I best get my finger out.
So I've started on my internal gear change, will get some pictures up when i get back from work.
Cheers, Paul.
#117 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 29 August 2023 - 02:09 PM
Cheers, Paul.
Look forward to seeing the progress!!
#118 72hump
72hump
  • 200 posts
  • Local Club: IMOG
Posted 20 October 2023 - 06:01 PM
Hi guys, what is everyone using these days to put pictures up on this forum?
#119 colinf1
colinf1
  • 1,015 posts
Posted 20 October 2023 - 08:04 PM
Flickr is pretty good, up to 1000 photos on a free account, easy to upload via the app, but only drawback is needing to use the Web version web page to copy the correct bbcode for forum...not difficult once you get the hang of it
#120 72hump
72hump
  • 200 posts
  • Local Club: IMOG
Posted 20 October 2023 - 08:28 PM
Thanks Colin, i've set up a Flickr account, will see if this link works.
https://flic.kr/p/2payffv
Edited by 72hump, 20 October 2023 - 08:29 PM.
