Ok then I will take it apart again today so i should have pictures by tonight. Hoping it will be simple so solve as i have had the clutch of twice already to check it so this will be the third time!
Clutch Problems! please help!
Mini Man Dan
, Oct 23 2006 09:24 PM
19 replies to this topic
#16
Posted 25 October 2006 - 07:55 AM
#17
Posted 25 October 2006 - 07:59 AM
At least it should come apart easily
#18
Posted 25 October 2006 - 06:49 PM
I decided to bump start my mini without the starter motor on so see if that was hitting to see if i could eliminate the noise but it was still there. So i have come to a conclusion that there is a problem witht the transmition as everything in the block has been replaced and taken apart and check again! managed to get mew gearbox for £40 in perfect condition Will let you all know how it goes......thanks for all your help!
#19
Posted 25 October 2006 - 06:54 PM
make sure you check the gap between the gearbox and the flywheel housing correctly, if its too tight you will tear the housing and the middle drop gear to bits!! its all in the older haynes books!! worth checking out!!
#20
Posted 25 October 2006 - 07:24 PM
Thanks for that. I got one of my dads friends who is a mechanic to come round and have a listen and he thought it was the started thats why i gave that a try.
