heated inlet
#16
Posted 25 October 2006 - 04:42 PM
Unless your feeling really brave and planning on using convection currents!
#17
Posted 25 October 2006 - 04:43 PM
#18
Posted 25 October 2006 - 04:44 PM
The water needs to go round the block to heat up.
It would work, but i wouldnt be sure how efficent it was and your heater may drop in temp.
#19
Posted 25 October 2006 - 04:50 PM
I dont think so, as the cooler water from the heater exit would be able to flow back across the manifold and back into the heater.
Was hoping on not having any more hoses all over the engine bay, but looks like it probably won’t work the way I had planed, so will have to plum it in like the first one.
#20
Posted 25 October 2006 - 05:47 PM
later cars with an in-line heater valve have a different pipe layout. !!!!
sorry to make things worse
also the MG metro and the carb Coopers have heated manifolds as standard so you may be able to use
the "off the shelf" pipes from these cars. (i'm just guessing )
#21
Posted 25 October 2006 - 06:14 PM
#22
Posted 25 October 2006 - 09:32 PM
#23
Posted 25 October 2006 - 11:11 PM
#24
Posted 26 October 2006 - 06:43 PM
When I get round to fitting my stage one kit, I was planning on pluming it in like this using t piece connectors of the hoses already there.
It will work to a degree, but, to wich degree is difficult to say. The coolant will always take the path of least resistance, and that my friend is, the inlet manifold. There is a reasonable presure drop across the heater matrix.
Plumb it in in series.
To overcome the problem of plumbing on earlier engines with the heater valve on the head, fit a sandwich plate under the thermostat, along with the correct bolts and rad bracket. Plum that to the inlet and the return, 'T' into theheater return at the bottom hose.
Better to have it plumbed in all the time so that it doesnt disrupt the tune of the engine with the heater on or off if plumbed the other way.
Mine has been done but it didnt do it so i duno how its done really
But from looking at it there is another bracker coming off the head underneeth the original radiator brakcer then hoses coming off that bracker going the the inlet.
Hope i might be going over to thanet tomurow so if i do i could robs pop over to you abd show you. But thats no definate yet.
Edit: ok you cant acctually see it in the pic much at all but its raining now so ill try and get some better pics when the weather gets better.
Yours was plumbed as standard from the factory and is the correct way to do it on later engines with the inline heater valve, As i did on the wifes 94 mayfair.
#25
Posted 26 October 2006 - 07:46 PM
Vapour lock,lol
It appears that the ambient temperature in the engine bay got so high, that the fuel was evaporating while in the manifold. It has a water cooled manifold fitted, but not plumb in. So i'm guessing in my mini's case, it is needed.
I'll plumb it in and see if it cures the problem!
And before you ask, the cooling system was opperating correctly.
#26
Posted 26 October 2006 - 07:49 PM
#27
Posted 26 October 2006 - 11:04 PM
