Rotary Coupling?
16 replies to this topic
#16 LionelMonza
LionelMonza
  • 68 posts
Posted 01 June 2020 - 04:25 PM
Ouch, I got the same scare, the black thing (top cover blew off, and the white roller undid itself!!!!!
On that, my wife came in and told me, but again you take this car apart...it's still going to break down...thank you for your trust !
in my case the cable is dissociated, the big yellow one makes the air bag, and for the horn 2 wires, black and black and purple, yes I'll try to change the position of the wires to see if it works.
Thanks to you all, thanks to you I'm going to make an appointment with the technical control at last!!!!!
#17 Wiggy
Wiggy
  • 1,037 posts
Posted 01 June 2020 - 08:33 PM
There's a little hinged flap on the back of the horn button connector you'll have to flip open before you can remove the pins.
You should only have to move either the red and purple, or both of the blacks. If you have a multimeter you can find out which 'path' in the coupler is broken.
Just make sure the new positions match up!
