Valve Adjustment S/c 1293
2 replies to this topic
#1 maccers
maccers
  • 1,882 posts
  • Local Club: LSMOC
Posted 23 August 2020 - 07:19 AM
Hi all, just in the process of refitting head and charger following a small top end overhaul. Engine is 1293 with Eaton dual injection / Emerald charger setup. I am using MED 1.3 roller tipped rockers.
I saw some advice to use the feeler blade from the side, vs the front so it does not roll in like a metal panel shaping tool.
I have no idea what they were gapped to before I removed them. Given the non standard spec I guess following the Haynes book won’t be correct, ie 12th and 15th.
The valve seats and valves have just been re-cut at machine shop so should be sealing well, its not been run for a few months.
Just wandered what the general feeling was, 12th across all or a mix?
Cheers!
#2 timmy850
timmy850
  • 3,603 posts
  • Local Club: MITG
Posted 25 August 2020 - 07:54 AM
Normally the camshaft will have a spec sheet with the valve clearances.
#3 maccers
maccers
  • 1,882 posts
  • Local Club: LSMOC
Posted 25 August 2020 - 09:02 AM
Its a standard SPi block and as far as I know the original cam. I just spoke to MED who advised if its the same cam, 12th on all 8 rockers.
