What Crazy Things Did The Last Owner Do To Your Mini?
#16
Posted 11 September 2020 - 06:07 PM
Left the the rear brake backplate fixings loose.
Fitted rear camber and toe adjustable brackets and adjustable tie bars without setting the geometry.
Were the most dangerous safety related items in a list of over 50 issues!
#17
Posted 11 September 2020 - 07:55 PM
This includes the clutch/flywheel but he had put the lock tab down..
Ball joints.. lock tabs down..
Hub nut with split pin in
Shocks
And various other parts all finger tight...
I get the feeling he spent a few years restoring it, run out of love so just chucked everything on in an afternoon to sell it as all the parts were brand new but just not really attached
#18
Posted 11 September 2020 - 08:07 PM
These really are making me laugh (and cry).
Its crazy what people do to Mini's!
if this was a competition, i really do think the copper piping would take the prize. Its somewhere between madness, stupidity and genius!
#19
Posted 11 September 2020 - 08:12 PM
Fitted quick release pins to the bonnet hinges as well as an internal bonnet release and rubber bonnet catches to the front of the bonnet.
Removed the top and bottom crash rails off the dash and fitted a home made facia but without a fixing for the instruments.
Fitted a stereo into the switch panel hole and fitted the switches and so on into the facia above.
Drilled 3 holes in the bonnet for air vents but cut one hole through the bonnet stiffener.
#20
Posted 11 September 2020 - 08:43 PM
I bought my old Mayfair from a girl who was going travelling back in 1999. She said that the stereo in the car was being taken out, which was fair enough as I was going to put my own in. What she didn't tell me as I got in to test drive and moved the seat was that the amp for said stereo was mounted on the crossmember under the driver's seat. When I moved the seat back I trapped my finger and it took about 5 minutes for me to get it out as I couldn't move the seat unless I put more weight on it, which crushed my finger further.
They'd also put cheap 6x9 speakers (white ones! ) in the back shelf - I can only assume that they'd used an axe to cut holes in the shelf as there were hideously dangerous spikes of metal pointing everywhere.
Thankfully it was a decent car so I bought it. The feeling eventually came back to my fingertip a day later (!) and my friend who worked at a car stereo shop tidied the vandalised shelf up with a nibbler.
#21
Posted 11 September 2020 - 08:54 PM
DSCF1545.JPG 338.35K
6 downloads
DSCF1549.JPG 346.01K
4 downloads
DSCF1581.JPG 365.36K
3 downloads
'nuff said...
#22
Posted 11 September 2020 - 10:20 PM
#23
Posted 11 September 2020 - 11:04 PM
Oversills, bolt in bleed nipple on calliper, 3/4 3 coats painted, rear 1/4 with one coat of paint, 3 slave cylinders wedge between bulkhead and subframe... lol
#24
Posted 12 September 2020 - 09:18 AM
'nuff said...
Errr, what is that? The love child of a Mini Clubman and a Landrover Discovery?
#25
Posted 12 September 2020 - 09:26 AM
Despite fully restoring and painting a bare shell prior to restoration the restorer used oversills and instead of using readily available floor pans used some sore of flat steel. Having said that its a superb job, well completed, totally solid and painted in body colour, Its waxed where it needs to be, doesnt go out in winter's salty roads so the oversills are not causing the harm they ordinarily would in a daily driven car. Ideally Id like to put a full heritage floor into the car to bring it back to how it should be but cant really justify the cost for something that only 'rivet counters' worry about. It hasn't stopped the car from winning best in show and best in class several times. It just irks me that they have gone to so much trouble restoring the car but to do hidden things wrong.
#26
Posted 12 September 2020 - 10:30 AM
#27
Posted 12 September 2020 - 11:13 AM
If it wasnt for oversills many minis wouldnt be here today. Like them or hate them, they have saved 1000s of minis
#28
Posted 12 September 2020 - 04:43 PM
The previous owner repaired the inner sills with some sections of 6mm thick steel plate ......
Maybe he was trying to lower the centre of gravity
#29
Posted 12 September 2020 - 06:15 PM
On my mini minus (grp shell) they had the electrical earths all coming together then bolted them though the inner ply wood rear quarter trim .?? Surprise they didn’t work!
Also they had moved the drivers seat that far back the lower seat belt mount also though they ply ???? Instead of the built in steel frame that takes the seat belt mounts .
#30
Posted 12 September 2020 - 07:05 PM
