The thrust washer is installed against the radius arm on the the inner and outer sides of the arm. The radius arm brackets are lined up and the thrust washer flat against the frame.
I thought I would fit the pin on the other side and it is the same, with about 11mm of thread protruding by the time the spring washer and nut go on it’s not enough for the nut to have threads protruding.
I am fitting the original spring washer and nut. My question is, am I missing something obvious? Should the thread protrude more or is it possible the replacement subframe has thicker metal so not as many visible threads? Should I fit a thinner nut and washer to allow for the less thread?
Any help would be appreciated. Cheers.
