Where the pin is fitted, the Subframe is laminated with (if memory serves) 3 layers. These may have spread a little. I don't know if in your top photo you've done the nut up, if you haven't, try that as that maybe the issue.
The Stub on the inboard end should be 1.050" from the Pin Shoulder. It might also be worth measuring.
I did tighten the nut on the top picture. Like you say it may pull in a bit when fully torqued. I’m just wandering why I measured the thickness of the subframe hole to be 10.5mm whereas Rusty measured his old subframe at just under 7mm?
Hmmm,,, OK. Check the stub length I guess.
Just to put it out there - your Subframe does appear to be quite sound, but it's not swollen from rust in there is it ? Looking at your 2nd Photo, there does appear to be some separation between the layers. I really doubt this is the issue, but best check all the same.
I measured the stub length and it is about 1 inch without getting my verniers out. The separation is a good idea, it is a new subframe to me but may have been in the shop for a while? Looking at the hole I can’t see any separation, the hole looks good. What I did notice is there are from what I can see 4 layers of metal, which is more than a previous comment I think. There is the outer and inner ribs which form the support for the trumpet. Then there is a layer from the front cross member and then the bracket for the brake pipe. The total thickness is resulting in the thread showing to be smaller than usual (from what I can tell).
The thrust washer and shoulder of the pin are hard up against the subframe so what protrudes through the subframe seems to be what I have to work with. To be clear, this is a Magnum subframe and the one I removed I presume to be original.
Edited by Mayfair94, 12 September 2020 - 09:11 AM.
