Radius Arm Pin Installation Question
32 replies to this topic
#31 mini-mad-mark
mini-mad-mark
  • 852 posts
  • Local Club: northants wot no brakes
Posted 13 September 2020 - 07:05 PM
Not easy to tell from the picture because its all black but it looks a bit like the brake hose fixing is extended across the radius arm pin hole (making an additional layer/thickness)
Not sure if this is correct as standard as I haven't looked at mine lately but I juts recall the bracket being cut back before reachin the hole
#32 Mayfair94
Mayfair94
  • 63 posts
Posted 17 September 2020 - 06:15 PM
Just went and got some quick and dirty measurments from the garage.
Presumed original subframe - both sides around 7mm thick.
Pattern Subframe - around 10mm (can only get to one side without dragging half the garage out).
Stub length - just over an inch.
Looks like I will have to deal with this in the future too....
Hi Rusty,
Thanks again for your measurements. Just to update you as I believe you have a pattern subframe, I fitted a plain washer and new grade 8 zinc plated nuts on each side with loctite and it all pulled together nicely. The bolt now is now just protruding through the nut.
Cheers guys.
#33 RustyAutoCityE
RustyAutoCityE
  • 320 posts
Posted 17 September 2020 - 06:49 PM
Hi Rusty,
Cheers guys.
Nice one, glad you got it sorted out.
I'm still a way off fitting mine, but I appreciate you letting me know what to expect and how to overcome it!
