Fog Light And Switch Not Working
electrical
7 replies to this topic
#1 liv011
liv011
    Starting My Mini Up
  • 2 posts
Posted 24 September 2020 - 08:51 PM
Hi
So I have a 1990 studio 2 and have been working on it over lockdown and the one thing I cant seem to get working is the fog light, and the switch also doesn't work. I'm just stuck for ideas for what it could be.
Any ideas would be greatly appreciated.
#2 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 24 September 2020 - 08:58 PM
Check there is power into the switch from the main lighting switch. Then bridge the wires to test the circuit and bulb
#3 KTS
KTS
  • 2,490 posts
Posted 24 September 2020 - 10:06 PM
hopefully you're aware that to get power to the fog light the headlights have to be on ?
#4 BAWrathall
BAWrathall
  • 29 posts
Posted 25 September 2020 - 07:00 AM
Like other have mentioned get a meter and check you got power to switch first , then you could link out and that would prove switch , I would recommend getting a power probe for around £20 you can quickly fault find as you can put power on bulb then put power on outgoing or switch etc , you can do all this with out one but easy over than linking out stuff ??
#5 andyapanel
andyapanel
  • 651 posts
Posted 25 September 2020 - 11:35 AM
On my cars, it is usually the fuse on the bulkhead that is to blame; they get a bit manky, sufficient to stop current flowing.
#6 MikeRotherham
MikeRotherham
  • 1,030 posts
Posted 26 September 2020 - 07:37 AM
I have the same problem with mine. Re adjusting the relevant inline fuse behind the carburettor cures it for a while.
#7 andyapanel
andyapanel
  • 651 posts
Posted 26 September 2020 - 12:47 PM
Yes, its one of those annual things.
#8 sonscar
sonscar
  • 3,249 posts
Posted 26 September 2020 - 07:50 PM
Like a pre MOT check,Steve..
Edited by sonscar, 26 September 2020 - 07:50 PM.
