(Video) Weird Noise Pre And Post Ignition
electrical engine
7 replies to this topic
#1 Gareth_A
Gareth_A
    Starting My Mini Up
  • 1 posts
Posted 09 November 2020 - 09:58 AM
Hi all,
Please would you help me figure out the following (video attached):
1) Turn ignition to on position and weird, repetitive sound starts
2) Turn ignition to start the car, engine starts, and sound continues
Please help me understand what this might be? ...and anything else that your experienced eyes / ears may note?
Year: 1973
Model: MK iii
Engine: 998cc
Assembly: South Africa
Video Link: https://streamable.com/ac7j3l
Thank you for your time and assistance.
#2 Ethel
  • 26,177 posts
Posted 09 November 2020 - 11:56 AM
Can't hear anything in particular. Noise without the engine running could only really be something electrical like a fuel pump or heater/radiator fan.
#3 Maccmike8
Maccmike8
  • 1,101 posts
Posted 09 November 2020 - 12:00 PM
Fuel pump. What type is fitted?
#4 Maccmike8
Maccmike8
  • 1,101 posts
Posted 09 November 2020 - 12:01 PM
Nice car by the way.
#5 mini-mad-mark
mini-mad-mark
  • 894 posts
  • Local Club: northants wot no brakes
Posted 09 November 2020 - 10:21 PM
Is this the fuel pump under the bonnet? Is it rubber mounted? this might be the noise - not sure how much if any difference rubber mounting makes as I've never had a mini with electric fuel pump - others might have something negative to say about rubber mounting and any effect it might have on the fuel delivery - sorry not an expert
Just a note your carburettor might be  a "left hand" carb from a twin carb set up  (the float chamber normally on the left of the dashpot looking at it from the front but yours looks to be on the right of the dashpot)
Attached File  Capture.JPG   46.57K   1 downloads
#6 cal844
cal844
  • 9,672 posts
  • Local Club: TFMOC
Posted 09 November 2020 - 10:43 PM
The noise is the electric fuel pump.
I'd move that fuel pump to the rear of the car so it pushes fuel. Then fit a filter and pressure regulator where the pump is currently fitted.
I've run the mechanical pump on my mildly tuned 1275 engine since I bought the car 5 years ago, then only changed it 2 years ago as we had the engine out to do a repair to the engine stabiliser bracket on the bulkhead crossmember. On a 998 engine you only need a mechanical pump, even on a full race engine as they don't need to pump much capacity or flow.
Yes the earlier 45° piped units are a little awkward to use but I find the 1990 onwards mechanical pumps work well as the inlet and outlet are sided.
Edited by cal844, 09 November 2020 - 10:46 PM.
#7 viz139
viz139
  • 694 posts
  • Local Club: Irish Mini Owners Club
Posted 09 November 2020 - 10:45 PM
Noise is the fuel pump, its normally located in the rear subframe under the car so you can't hear it. The metal bar from the rad to bulkhead without any rubber mountings wouldn't help with noise either.
#8 gazza82
gazza82
  • 3,031 posts
  • Local Club: TMF+
Posted 10 November 2020 - 02:15 PM
Unless it is a "pull" pump.
Also tagged with one or more of these keywords: electrical, engine
