Posted 01 December 2020 - 11:12 PM
Using a mot emission tester I can see that the emissions are very high on start up but as soon as the fans come on it’s like a switch is flicked and the emissions drop right down.
Any ideas what could cause over fuelling on star up? My guess is a engine management sensor or poor fuel injector management set up. I would be great full for any suggestions.
Thank you.
Posted 01 December 2020 - 11:59 PM
From cold, they do run super rich. Once the car is hot and the fan not turning, are the emissions stoich at idle?
Posted 02 December 2020 - 08:46 PM
Posted 02 December 2020 - 08:49 PM
Posted 02 December 2020 - 09:27 PM
I am no expert in MINI injection but based on my standalone EFI cars the temp sender tells the ECU to run off the main map as warmup is finished.It then uses a combination of rpm and manifold pressure to inject the correct amount of fuel.The lambda sensor fine tunes this.Without live data it could be any/all of these or exhaust leak,failing cat fuel pressure regulator fuel pump worn out engine and lastly anything else.You need to see the data the ECU is seeing and use some interpretation of the readings.Good hunting.Steve..
Also tagged with one or more of these keywords: engine, electrical
Mini Technical Sections →
Problems, Questions and Technical →
Broken Headlight Stalk On InnocentiStarted by IceBlue , 25 Aug 2025 ![]() |
Excessive Fuel Pressure - Regulator Or New Pump?Started by daddums , 20 Aug 2025 ![]() |
Econoseal Or Something Else?Started by o0OWILKSO0o , 13 Aug 2025 ![]() |
Trying To Find The Right Wire Harness Online...Started by mattaebersold , 22 Jul 2025 ![]() |
What Size Are These Main And Big End Bearings?Started by scottyboy805 , 19 Jul 2025 ![]() |
