Mornin! From Spain
20 replies to this topic
#16 gaspen
gaspen
  • 980 posts
Posted 04 January 2021 - 08:37 PM
"1000 De Lujo" or DeLuxe in English :)  Cooper's VIN should start with GT....
Attached File  MML.png   161.16K   0 downloads
#17 sigfurniture
sigfurniture
  • 23 posts
Posted 04 January 2021 - 10:37 PM
excellent work gaspen..thanks a lot..nice to know a bit of the back ground of the story..the previous owner was pretty un helpful. the lujo part (luxury) will suggest the interior trim i suppose..does it explain the disc brakes?
Edited by sigfurniture, 04 January 2021 - 10:38 PM.
#18 Itsaminithing
Itsaminithing
  • 853 posts
  • Local Club: Not One Worth Mentioning
Posted 05 January 2021 - 12:10 AM
Looking more closely at the engine bay....
That's an Authi Hydrovac-Bendix brake servo & it still has the Authi radiator (thicker than the UK version).
I cant make out if that is a 1275 A or A+ series engine. Is the engine number stamped directly on the block or does it have a riveted engine number plate?   -Authi always stamped their engine blocks. The engine could be from a Authi Mini-Cooper, or the Authi version of the ADO16.The Authi engine numbers are fairly easy to identify.
Gaspen will hopefully be able to identify everything that was original -as he owns an Authi & has done a lot of research on them.
http://www.austinmin...thi1000mk3.html
http://www.minipassi...0 1000 1970.pdf
http://www.austinmin...nt_authi.html   (not sure that this is a complete list as i've found some Authi Minis were painted in other colours).
Edited by Itsaminithing, 05 January 2021 - 08:46 AM.
#19 gaspen
gaspen
  • 980 posts
Posted 05 January 2021 - 08:26 AM
I think that your car is a Mini 1000 and it does not had disc brakes from factory. Only the 1275 models had disc brakes (1275 C, 1275 GT and the Authi Cooper ) It seems that somebody upgraded to disc brakes together with the A+ engine.  Authi engines were painted brown.
Deluxe means the interior instead, but the rear opening side windows were the also the part of these cars. And I see the aerial hole at the rear right corner of the car - unique for Authis  :shifty:
Attached File  Authi motor 1.jpg   50.03K   0 downloads
Attached File  authi motor 2.jpg   35.29K   0 downloads
I share you the parts catalog for Authi, I hope you can use them.
https://drive.google...iew?usp=sharing
#20 gaspen
gaspen
  • 980 posts
Posted 05 January 2021 - 08:44 AM
If you registered on FB you should join the Authi group, they are very helpful
AUTHI MINI REGISTER GROUP | Facebook
#21 sigfurniture
sigfurniture
  • 23 posts
Posted 05 January 2021 - 12:10 PM
just registered gaspen..thanks for that and all the info..likewise itsaminithing..those catalogues are great 100 000 peetas for a new car !!..hehe..just what i needed..i´ll check the details on the engine next time i´m up at the mechanics..hes finishing off the battery connections and fuel tank stuff
cheers guys..ace !
