I also have the red dot cones and minispares high lo's. Only drove it for 100miles max. I did not measure anything but after initial fitting the car was very high. After a few miles it allready settled. I can place 4 fingers between top of the wheels and the fender.
The hi-lo is nearly on its lowest point. Will drive as much as I can for now and see if it settles even more.
Can I turn the hi lo's all the way in, or do you always have to lock it with the locknut on the thread?
I'm not after an ultra low setting, just stock hight or slightly lower.
I also have a problem now that I cant turn them much lower as on full extension of the suspension the cones tend to get lose, an issue that I did not foresee. I have AGX dampers, basically I have the whole minispares kit with adjustable everything, AGX dampers and red dot cones.
I must say that I love the comfort of the cones and suspension, best on any Mini I've ever owned.
Cheers,
Dennis
Modification Of Hi Lo Trumpet
croc7
, Jan 13 2021 10:01 PM
45 replies to this topic
#46
Posted 15 January 2022 - 10:10 PM
