Picture Of T3 In Engine Bay?
19 replies to this topic
#16 Project_1275_GT
Project_1275_GT
  • Just Joined
  • 341 posts
Posted 30 January 2021 - 01:59 PM
I'm glad I did mine in an MPi subframe, it moved the engine forward 13mm and then i leaned the engine forward. Loads of room!
Again I had no idea the later subframe moved the engine forward, Is this just the MPI subframe? My subframe came from a much later mini but not MPI.
I believe SPi onwards it moved it forward to clear the inlet manifold and air box.
my subframe came from a 1992 - 998 so im pretty sure it will be standard style. Hopefully with the adjustable top steady it will all fit. The new turbo inlet connection should save some room. I hope
#17 Ethel
  • 26,825 posts
Posted 30 January 2021 - 04:21 PM
Not totally sure what's what with your drawings.
The internal machining of the compressor housing is to very close tolerances, if you were thinking of replacing it.
I moved my wastegate actuator to  next to the carb by grinding the lever free, turning it 90 degrees then rewelding it to the shaft. Made up a bracket to secure the can to the turbo/manifold flange.
#18 Project_1275_GT
Project_1275_GT
  • Just Joined
  • 341 posts
Posted 30 January 2021 - 06:31 PM
In the pictures the compressor housing is drawn poorly as i couldn't be bothered. But its the original housing drawn to scale. The original actuator bracket and connection for air inlet or filter is one piece that bolts on with 2 screws. The drawing shows a new box that replaces the original inlet and creates a new vertical inlet that should be closer to the engine than original. simply bolts to the front of the compressor housing.
[attachment=211688:7 trim.png]
This just bolts to the front of the compressor housing
Edited by Project_1275_GT, 31 January 2021 - 10:07 AM.
#19 Ethel
  • 26,825 posts
Posted 30 January 2021 - 10:44 PM
Site:turbominis.co.uk+air+filter - see if that chucks up anything of use in google images.
#20 Project_1275_GT
Project_1275_GT
  • Just Joined
  • 341 posts
Posted 31 January 2021 - 10:09 AM
Site:turbominis.co.uk+air+filter - see that chucks up anything of use in google images.
Thanks for that. I found some that get close to the area. Think I will make the unit and modify if necessary when it all goes in
