Pistons-1275 Std Bore-Where?
engine
16 replies to this topic
#1 PoolGuy
PoolGuy
  • 848 posts
Posted 12 February 2021 - 08:31 AM
Why can't I find any 1275 standard bore pistons with a 6.5cc (or similar) offset dish? Everything is oversize. I want  a decent cast piston but can't find any?
It seems crazy that I may have to go +20 after lining the block back to standard. I don't need forged pistons, but the extra cost of them would be slightly offset by the reduction in machining costs, so not out of the question.
Is a reasonable quality standard size piston too much to ask?
#2 lordcakes
lordcakes
  • Just Joined
  • 149 posts
Posted 12 February 2021 - 08:59 AM
Bullmotif had some listed. Is this what you are after?
https://bullmotifmin...19320_p21253-00
Edited by lordcakes, 12 February 2021 - 09:01 AM.
#3 Aria Aradhea
Aria Aradhea
  • 563 posts
  • Local Club: Jakarta Morris Club
Posted 12 February 2021 - 09:05 AM
Minispares have some: http://www.minispare...px|Back to shop
And there's another with low compression ratio as well...
Or is it different?
#4 gazza82
gazza82
  • 3,014 posts
  • Local Club: TMF+
Posted 12 February 2021 - 09:20 AM
Tried FW Thornton??
#5 GraemeC
GraemeC
  • 7,438 posts
Posted 12 February 2021 - 10:17 AM
Why offset dish?  That might be the hardest thing.
Otherwise std pistons should be relatively easy to find, as above.
#6 PoolGuy
PoolGuy
  • 848 posts
Posted 12 February 2021 - 12:09 PM
I’d seen the ones linked to, I was hoping for something a bit better, Omega (as mentioned) would be preferable, Swift, Med etc all list decent pistons but they’re all over size.
Why do I want the offset dish? I need the dish, and if I’m going to have it I want it offset. Simple as that.
#7 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,037 posts
  • Name: Neil
Posted 12 February 2021 - 02:52 PM
Why don't you go direct to Omega with your requirements and see what they can do for you???
https://www.omegapis...com/pistons.php
#8 ACDodd
ACDodd
  • Mini Docs
  • 2,745 posts
Posted 12 February 2021 - 04:51 PM
Very difficult to find adms the vast majority over bore the engine. Before contemplating linering you must check availability of pistons.
Ac
#9 PoolGuy
PoolGuy
  • 848 posts
Posted 12 February 2021 - 05:43 PM
Sonikk, I tried Omega direct, not heard from them yet.
AC, that’s what I’m doing  ;D But it’s looking like I’ll have to go 1293.
#10 Spider
  • 14,881 posts
Posted 12 February 2021 - 06:21 PM
Maybe give the likes of Swiftune a call. While they may not list them, they may have some or being a stockist, they would likely get a quicker response from Omega. I think what your after isn't that unusual or odd.
#11 PoolGuy
PoolGuy
  • 848 posts
Posted 12 February 2021 - 06:45 PM
I know, I didn't even see it as a problem when I was chatting about it with the guy who's doing the block.  I'll see what Swifty says.
#12 PoolGuy
PoolGuy
  • 848 posts
Posted 15 February 2021 - 01:56 PM
Update: MED don’t stock std size and are only interested if they can shift 25 sets.
#13 Dusky
Dusky
  • 5,322 posts
Posted 15 February 2021 - 02:55 PM
What’s the advantage of the offset dish?
#14 PoolGuy
PoolGuy
  • 848 posts
Posted 15 February 2021 - 03:02 PM
It’s said to increase power over a central dish. I’m not going to get into an argument about it though as it’s a bit of a can of worms for some people. You may think it’s worthwhile if you were fortunate enough to see what’s been done to Miglia engines over the years.
#15 Dusky
Dusky
  • 5,322 posts
Posted 15 February 2021 - 06:01 PM
Do you know why? Not something I’ve ever seen on other engines, can only imagine the piston isn’t 100% centered under the sparkplug in stock engines? Always happy to learn
