I need a new rear subframe for my Mini Mayfair (Reg 1992) which one do I need?
Also Minisport offer a fitting kit is it worth getting one?
What else should I replace at the same time, I thought of the new cones any other items?
Posted 18 March 2021 - 07:15 PM
Posted 18 March 2021 - 07:46 PM
Posted 18 March 2021 - 08:10 PM
I maybe would not replace any good condition original rubber items with most of the modern reproduction rubber parts for Minis which seem to disintegrate very quickly.
The rear subframe required varies on the type of exhaust hanger mountings used.
If you have the 1991 on type with mounting prongs for the exhaust rubber straps then you require:-
http://www.minispare...c/MS45LATE.aspx
Edited by mab01uk, 18 March 2021 - 10:35 PM.
Mini Technical Sections →
Problems, Questions and Technical →
Mot Advisories On Potential PurchaseStarted by billlifferr , 12 Jun 2023 suspension |
Fitting 10” Wheels On My Mini Convertible (Spi)Started by Dalla , 29 May 2023 suspension, brakes |
Radius Arm - Reaming Or Beyond Repair?Started by Chelsea_Pete , 04 May 2023 suspension |
Correct Upper Suspension Arm Tightening Process?Started by Dakinn , 03 May 2023 suspension |
Track Rod End Thread Engagement / Adjustable Lower ArmsStarted by YankWithAMini , 02 May 2023 suspension |
