Cv Nut Removal
suspension
4 replies to this topic
#1 spi
spi
    Just On Tickover
  • Just Joined
  • 6 posts
Posted 02 April 2021 - 09:10 AM
Stating to remove front suspension to clean up arms hub etc.
What is the best way to undo the cv nut with sub-frame off the body & no brakes?
Is it best to blast the arms & hub to clean off any rust?
Thanks for all replies in advance.
#2 Ethel
  • 26,181 posts
Posted 02 April 2021 - 09:40 AM
Clamping the disc in a vice with some soft jaws probably,. You might also manage it by fastening it to something with the wheel studs.
However you clean 'em protect any mating surfaces: bearing seats etc. A wire brush in a drill should do good enough.
#3 nicklouse
  • 18,767 posts
Posted 02 April 2021 - 11:00 AM
Opps. One of the first things to undo before removing the subframe.
piece of angle with 2 holes in it. Hold onto the hub with wheel nuts. Won’t move.
#4 r.tec
r.tec
  • 202 posts
  • Local Club: SfG Schoenau
Posted 02 April 2021 - 11:10 AM
compressed air impact wrench
#5 TheFabMini
TheFabMini
  • 459 posts
Posted 02 April 2021 - 02:56 PM
7 Ugga Duggas
Also tagged with one or more of these keywords: suspension
